1NZ-FE differences?
I was doing research into the 1NZ-FE engine. I was just looking at engine code considering how few references I could find for specifically a Scion xA. I found out that many people do a throttle body swap. Typically you could swap a throttle body from either a 1.8L 1-ZZ from Corolla or Matrix but also from a 2.4L Camry. Both these were basically same throttle body being nearly an inch wider than the 1NZ-FE. But as I noticed all these were drive by wire throttles and the Scion xA is a drive by cable. But many other 1NZ-FE are drive by wire.
I was wondering if the Scion xA just had to sit out this throttle body upsize due to this issue and if anyone else knew anything about this to shine light on the topic for me. *Moved to Correct Forum by Administrator Sticky Where to Post Your Question Sticky How To Advanced Search SL (Scion Life) ______________________________ |
If you do a search you will find all kinds of detail on xA/xB throttle body swaps and you need to source one that came from a cable-operated throttle. I'd imagine very minimal gains for the hassle but the throttle body you would need are relatively inexpensive on eBay.
Originally Posted by Hverner
(Post 4304349)
from Corolla or Matrix but also from a 2.4L Camry. Both these were basically same throttle body being nearly an inch wider than the 1NZ-FE. But as I noticed all these were drive by wire throttles and the Scion xA is a drive by cable. But many other 1NZ-FE are drive by wire. I was wondering if the Scion xA just had to sit out this Throttle Body Up size due to this issue and if anyone else knew anything about this to shine light on the topic for me. Just thinking but if you leave the cams and cylinder head alone is making the TB just a tiny bit bigger going to help? It just flows into the air box and then everything else behind that is stock you'd at least also have to port match everything. ______ |
