1st gen scion xb cat-back
Old Feb 17, 2009 | 03:44 PM
BlackBox06's Avatar
Default 1st gen scion xb cat-back
i Purchased a greddy sp2 exhaust not too long ago and i was under the impression that it was cat back. wehn i received the package i opened it up to find only the rear section exhaust. i called greddy and they informed me that they dont make a cat-back exhaust system for the xb.....something about everything is welded together or somethin like that. i was just wondering what kind of work and money is involved is customizing that section of of pipe (from my dc sports header-to the axel back)?????
Old Feb 17, 2009 | 04:10 PM
jct's Avatar
jct
do a two inch mandrel bend exhaust tubing with a 2" in and out magnaflow resonator... for your mid pipe
Old Feb 18, 2009 | 04:15 AM
B2FiNiTY's Avatar
you can also buy a obx midpipe and get that welded.
Old Feb 18, 2009 | 10:10 AM
bB384's Avatar
IV ACE
Default Re: 1st gen scion xb cat-back
Coming from your header you have; 2 inch piping, pre-cat O2 sensor bung, Cat., post-cat O2 sensor, 2 inch piping into resonator, the resonator itself, 1 3/4 piping out the resonator going to the rear axel where your exhaust bolts up everything is indeed welded together where on most cars the mid pipe usualy bolts up to your cat. xA/xB owners got screwed. You could go to a muffler shop and have 2 inch piping done from the cat back but you would have to use the OEM connection for your muffler since its a secific type, which would render your piping since its Diameter is still 3/4. You real alternative is to not use the OEM connection at the rear axel by welding it all together or using a generic flange. either way its a lot of work just to make the car annoying and loud. I did it and I regret it.
Old Feb 19, 2009 | 02:31 AM
BlackBox06's Avatar
so then its basically alot of work for really no improvement in performance? i kinda figured that...with such a tiny motor im trying to get all that i can out of it
Old Feb 19, 2009 | 04:21 AM
jct's Avatar
jct
yall got it wrong...
from the header to the cat its 2.5inch diameter... from the cat to the resonator its 1.75 inches... and its the same diameter from the resonator to the muffler
Old Feb 19, 2009 | 07:13 PM
bB384's Avatar
IV ACE
Are you measuring outside diameter or inside diameter? Because from the header to the cat the walls on the piping is pretty thick.
Old May 8, 2009 | 10:12 PM
OakToddler's Avatar
Can anyone confirm the size for me?
Pipe size going into resonator and size coming out of resonator.
thanks....
Old May 9, 2009 | 02:06 AM
jct's Avatar
jct
thanks....
1.75" in and out
header to cat is 2.5" cat to resonator 1.75"
so pretty much that after cat tubing diameter screwed us over
Old May 9, 2009 | 03:12 AM
OakToddler's Avatar
If I just wanted to put a cherry bomb in the resonators place or something glass packed like that. I have to have 1.75 inlets then. right?
thanks btw
Old May 9, 2009 | 02:03 PM
jct's Avatar
jct
yes 1.75 O.D. for the exhaust tubing
Old May 9, 2009 | 02:08 PM
OakToddler's Avatar
So, I could not use a 2 inch inlet cherry bomb?
Old May 10, 2009 | 01:52 AM
samhain's Avatar
I wanted to do the same thing with a Cherry Bomb glass pack. Let me know how it works out and if you do it.
Old May 10, 2009 | 02:11 AM
EAmon's Avatar
i have a cherry bomb glass pack waiting to be put in, lol, been to lazy to get it done
Old May 10, 2009 | 03:33 AM
OakToddler's Avatar
What size cherrybomb do you have? What are your plans?
Old May 10, 2009 | 03:36 AM
jct's Avatar
jct
i'm running two resonators a magnaflow and a 12 inch cherry bomb
and my muffler still gives me a nice tone in my exhaust note
Old May 10, 2009 | 04:33 AM
EAmon's Avatar
mines 2" in/out planning to get the rez taken out w/the piping and getting 2" piping from teh glasspack back also flanging the res and glasspack so i can swap em in and out if ever needed
12thhawksfan
Jul 14, 2015 06:18 AM
EthanAJS
Dec 21, 2014 10:16 PM
PTUNING
Dec 11, 2014 08:09 PM
foxSCION
13
Dec 3, 2003 05:40 AM
