2006 xA multiple cylinder misfires
Old Sep 26, 2018 | 11:52 PM
DPK99's Avatar
Default 2006 xA multiple cylinder misfires
Greetings all,
My 06 xA (~130,000 miles) is reading cylinder 1 and 3 misfires (separate codes not the multiple code). After driving for a couple of minutes, the engine will sputter and gasp and the air filter box will start to shake. This first started happening when I was out of town for 2 weeks, and when I got back home, the check engine light came on and the sputtering started. I was hoping that it was from sitting for two weeks, but I wasn't that lucky. The spark plugs were replaced about 15 months ago and since there are TWO cylinder misfires, it tells me something else could be going on. Any thoughts?
Thanks!
______________________________
Last edited by MR_LUV; Sep 27, 2018 at 04:13 AM. Reason: Moved to Correct Forum by Administrator
Old Sep 27, 2018 | 06:02 PM
MileHightC's Avatar
Super Moderator
SuperMod
Try swapping coils packs, clear the codes and see if you get new misfire codes and what cylinders they might be for...based upon mileage I would guess you're having coil pack issues, especially if you just put new plugs in.
Could be injectors also but I doubt it.
Old Sep 29, 2018 | 03:21 AM
DPK99's Avatar
There was a good amount of water that filled up one of the spark plug slots Getting rid of the excess water seems to have solved things, for now.
Old Sep 29, 2018 | 04:52 PM
MileHightC's Avatar
Super Moderator
SuperMod
That will certainly do it...
groundskeeperwilly
Oct 2, 2019 10:59 PM
sarahswalk
Jun 13, 2016 11:37 PM
davidward
27
Feb 2, 2015 02:07 PM
bce181
Dec 24, 2011 01:27 PM
etoomey3
26
Aug 2, 2009 08:05 AM
