2ZZ-GE Engine Swap in my 05 Scion xB
Old 05-03-2018, 05:24 PM
Porsche's Avatar
Default 2ZZ-GE Engine Swap in my 05 Scion xB
deleted my post. Carry on
Porsche is offline
Old 05-04-2018, 01:11 AM
Porsche's Avatar
I got the engine started shortly after my first post today. I’ll post a video on YouTube and link here later
Porsche is offline
Old 05-04-2018, 02:27 AM
jct
jct's Avatar
sounds more like that guy paid a shop to do all the hard work and poof a simple swap
jct is offline
Old 05-04-2018, 02:32 AM
Porsche's Avatar
Lol it’s my car and I worked on it along with one of my mechanics. I own the shop. Don’t think I’ll be updating here though
Porsche is offline
Old 05-08-2018, 01:15 AM
jct
jct's Avatar
and that's cool cause this place is like an abandoned town
jct is offline
Old 05-09-2018, 01:40 AM
jct
jct's Avatar
Found the video where the guy said he put on in the xB which found to be totally false...
jct is offline
Old 05-11-2018, 06:50 PM
Porsche's Avatar
After rereading your first post I think you were referring to that other guy on YouTube. If that's what you meant then I apologize for what I said.
With that being said let me give you guys an update. So the engine is in and all 4 motor mounts are on. All of the accessories are attached as well. I had to use a lot of Celica GT-S parts for the non engine components. It was a whole lot of custom work.
Now I'm waiting on Celica wheels, the fronts are going to be 15x6.5 and I'm going to keep the rears 15x6 and got some rubber on the way 205/55/15. The next thing on the list will be the wiring, which is gonna be a lot of hard work. I'll post a vid on YouTube when the car is all finished.
Porsche is offline
Old 05-11-2018, 06:53 PM
Porsche's Avatar
How did you find out he was lying?
Porsche is offline
Old 05-14-2018, 01:03 AM
jct
jct's Avatar
Simple 2zz-ge Motor Swap? - Scion xB Forum
jct is offline
Old 05-14-2018, 03:03 PM
Porsche's Avatar
I saw that thread, it doesn't mean he doesn't have a 2zz in there.It does sound like it could be more than bolt ons. On the other hand I don't know how he kept his car 4 lug, but he could've just went a different route from me.
Porsche is offline
Old 05-17-2018, 04:29 PM
Super Moderator
SuperMod
MileHightC's Avatar
And still no pictures...
MileHightC is offline
Old 05-17-2018, 05:42 PM
Porsche's Avatar
Porsche is offline
Old 05-21-2018, 09:20 PM
Super Moderator
SuperMod
MileHightC's Avatar
Looks as if there is still a fair bit of work to be done...I researched the 1ZZ and 2ZZ swaps and both of them are far from bolt-in and require a good deal of customization as you're finding out.
After researching these two options, pricing out costs including built motors that produced a fair bit of power and just general hassle, I've decided a turbo 1NZ is the way to go. Even building the motor and fabbing the hot and cold sides for a turbo is far easier than either of the ZZ swaps from what I can see.
Old 05-22-2018, 02:18 AM
Porsche's Avatar
i’m Almost done actually. Put in a custom battery bracket, radiator, coolant, ps fluid and started her up. I’m gonna replace the alternator tomorrow cause it’s bad and add some trans fluid. Then I’m going to take it to the muffler shop and get an alignment.
total cost so far is around the $2k mark
Porsche is offline
Old 05-23-2018, 01:10 PM
Super Moderator
SuperMod
MileHightC's Avatar
But the 2ZZ is just a 'puller' motor, correct...it hasn't been rebuilt?
Old 05-23-2018, 02:28 PM
Porsche's Avatar
yes. I just did the timing gasket, valve cover gasket. Engine was really clean when I opened it up and runs great
Porsche is offline
Old 05-28-2018, 06:45 AM
Gerry's Avatar
Nice job!
Gerry is offline
Old 06-20-2018, 07:57 PM
Jpgillespie24's Avatar
Where are you located? I’m out in Vegas and can’t find a shop that’s willing to do this. Would you be interested in swapping my xB?
Jpgillespie24 is offline
Old 08-07-2018, 01:25 AM
mr2gq's Avatar
I came across this thread and figured I would join two so I could respond LOL. I'm in the middle of a 2-ZZ swap myself and I'm not sure why the wiring is the hard part. Matter of fact it's extremely easy. Y'all probably don't know this but the 2003-04 Matrix is a better donor. Simply because the ECU is plug and play. You could use the engine harness but it's slightly different than Scion where it connects to the fuse box on the driver side. So I just used the Scion engine harness. The only thing you need from The Matrix harness is the two wires that go to the lift cylinder Lloyd and then the wire that goes to the lift oil pressure switch. If you have a 06 Scion I believe they already have the two wire knock sensor but if you have a older model like me you'll have to snag the wires for the knock sensor and then you just hook those wires to the corresponding location in the ECU plug. It will still run without it. Matter of fact my xA is an automatic and the Matrix manual transmission ECU will crank up and run the1-NZ Motor. I will be keeping the 4 lug. I will be using all Factory parts nothing custom as far as the draft ran other than the driver side transmission mount
mr2gq is offline
Old 08-07-2018, 08:40 PM
Super Moderator
SuperMod
MileHightC's Avatar
You'll have to let us know how it runs and feels in comparison to the 1NZ you replaced...in my opinion, unless you're going to build the 2ZZ and go with a healthy N/A setup or boost it seems like a lot of work to have, what is essentially, a 'top-end focused' motor.
Quick Reply: 2ZZ-GE Engine Swap in my 05 Scion xB
