Another DC header install with pics
Install wasn't too hard. Having a mirror so you can see the header bolts helps, getting the two spring bolts back on and off is REALLY hard. Youll need lots of extensions, some WD40 is helpful.
car doesn't sound any different.
both headers weigh 6 lbs, but you don't put the heatshield back on so maybe you save like 1 pound with the DC header.
it doesn't sound any different? do you have a stock exhaust or aftermarket? I would think it would make a lil difference. Does it feel like it has more power?
BTW THIS IS MY 1000th post!!! WOOOOHOOO i made it to the BIG TIME!
the AEM intake made the car sound much different.
the header did not, sounds the same.
feel more power? maybe, maybe not.
I don't trust my butt to sense tiny horsepower differences.
mebe when I get back to TWS again I can see if I hit a higher top speed on the main straight =)
Originally Posted by hnefrdo
im getting a header before i get an intake. they cost about the same, but headers make more power. it just seems sensable to me to do it in this order. does that make sense?
ive yet to see a dyno test of any header, so I wouldn't jump to the conclusion that it will add more power than an intake.
as for changing the rest of my exauhst, I don't plan too. I take my muffler off entirely for racing, and I prefer to have it quiet stock.
Originally Posted by Munch
Why do the exhaust and collector holes look so much smaller than the stock unit. Yet the pipes are bigger???
the stock manifold is two parts, the flat metal part has huge holes, but the actual pipes are much smaller, you can make it out in the pictures just barely.
Originally Posted by rampagesd
is it me or does the stock ports look larger?
try reading the thread guys!!
the stock ports are not larger. READ up above..
heres some help, the red lines shows the size of the ports, and ive brightened it for you
[/img]
Originally Posted by tbblizzard
so did you need to buy a new gasket or did it come with one or did you just use your old one?
Install took like 3 hours.
Its really pretty easy if you have the extensions youll need.
getting the spring bolts back in is super hard though.
