anyone modify and AEM to fit with fog lights?
I have purchased an AEM intake for my 06 box. its the cold air not the short ram but wasnt thinking when getting it and i have fog lights. So it doesnt work. My question is has anyone modified it so it will fit? I was thinking of cutting off the last 90 so the filter sits sideways instead of straight up. Would this work? The intake does have the bypass filter. Does anyone see a problem with doing this?
i have an easier fix, no need to cut, and this is what the dealer did on my 04 which came with the aem cold air.
look under the front drivers side, in front of the tire, but behind the front lip... See where the intake bracket bolts up to the box... (i'm talking about the lower mount, the one you can only see when you have the car up on a jack, just a few inches from where the bottom of the filter is). i dont know exactly how to describe the location of the bolt, but if you dry assemble the cold air on the floor you can see the bolt up location i am talking about.
Take the bolt - should be 2-2.5'' long... Get a 1'' nylon spacer, or like 20 washers to go over the bolt.. then install the CAI with the mounting tab under the spacer. This will move the top of the filter down enough to clear the left fog light. If you dont know what i'm talking about, or want to see a pic, send me a pm, and i'll take a quick pic, and post to this thread.
personally, i would not cut the tubing if it were me, its much easier to install a spacer.
i was surprised how long it actually was when i removed it once, and i thought, damn, this thing just keeps turning!
i'll go snap a pic on my next break, and post up shortly within the hour.
ok, strike that... my car is too low and my camera is too big to get underneath w/o jacking the car up.
basically its the only bolt that secures the lower section. if you pull it out, and its short, simply go to the hardware store and get a longer bolt, while you are there getting a spacer to fit over said bolt
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
carid
Jan 8, 2015 11:33 AM
