App. cost to replace engine?
I have discovered that my 2005 xA has a leaking head gasket (coolant into cylinder). It seems manageable right now but inevitably I'll have to have the head gasket fixed or the engine replaced.
I've seen many opinions on here and other sites that say that one would be better off having the engine replaced than fixing the head gasket. Many beleive that if the head gasket is blown there will be other problems with it - block cracks or warped heads in particular .
Many have said that at about $500 for a used engine it would be cheaper. But since this is not something I can do myself I have no idea what it would approximately cost to have a shop do it. I will not take it a to a dealer and I do have a place I think I can trust.
But I have no idea about how much labor will be charged. And although $500 seems to be the price thrown around for an engine alone, it does not include shipping. And I've been told that many shops won't install an engine you buy - they will only install engines they have source out - not only because of their cut, but also they have learned to trust the quality of their suppliers.
So am I talking about $1500 to $2500 total? Or more? And would that mean just fixing the head gasket would become more attractive?
Replace it then have the same shop replace the Head Gasket and take it back to the place where you bought the replacement and sell it to them. (Don't try to return it, they have Serial Numbers)
Its not hard to pull a motor... where are you? I kinda have experience in this area...
Read as: I could prob swap a motor in my sleep, with as often as i build/boost/break/replace em
Well im sorry to report but your about 1100 miles from me... so sorry that I cant help...
but there is something you can to do "patch" it. Go to your local auto parts store, and ask them for some liquid glass, yes, the same stuff used during cash for clunkers to seize the engines.
Start the car and let it idle for a little bit to get up to operating temp (right when the blue light goes away on the dash)
shut the car off
Open coolant system, pour in about a cup
Close coolant system
Start car and let idle for another 5 minutes
you may need to repeat the process a time or two to make sure you get the HG sealed properly...
BTW, Im not making this up... it works Plus there was a whole big ordeal about it when CFC first started
http://online.wsj.com/article/SB124934376942503053.html
shut the car off
Often called liquid glass, sodium-silicate solution has been better known for being used to save motors rather than killing them: It is used to stop leaks in the gaskets that seal cylinder heads to engine blocks.
Thank you so much for the offer to help swap the engine and for the info. I have been checking out the different sealing products - I'm hoping this will forestall doing something drastic for a long time.
DaBlackBox
134
Apr 10, 2022 02:04 PM
