Is this a Common Issue or just me(i put it in the wrong section)
Old Oct 5, 2010 | 07:09 PM
gp1817's Avatar
Default Is this a Common Issue or just me(i put it in the wrong section)
ok i have a 06 tc with about 58xx miles on it,i recently changed my tranny fluid from oem to Motul gear 3000,cause going into different gears were rough where i couldnt feel them,almost like metal to metal scraping,sometimes its smooth but for the most part,it rough i cant feel going into the gears like i use to, the shifter feel looser almost like i have no bushings, even though i have the Dr.iso cable bushings,i actually double check them to make sure they were loose,they were fine,but when i fist put the bushings in my shift felt nice and tight but over the months,just feels alot looser,but my main issue is that going into gears isnt smooth,i read the manual regarding first and reverse arent suppose to be smooth sometimes,not sure its werd,feels like there no lubicant in the tranny even though there is,like that rough shifting feeling,is there anything else i can check or grease up besides the shifter bushings and the tranny oil,do you think maybe my tranny needs to be looked at
i meant to put this in the tc section ,so please mods can you move it sorry
Old Oct 6, 2010 | 04:12 AM
VIP_CAMO's Avatar
Big Sky Scion
While you are driving does the it come out of gear?like say you are in 5th and then it just pops into nuetral?Do gears grind aswell when shifting?And this is the xa/xb section im sure someone will move it
Old Oct 6, 2010 | 04:40 AM
DeathStalker's Avatar
check for leaks, make sure the fluid is topped and hopefully its not the clutch or bearing
Old Oct 6, 2010 | 12:41 PM
gp1817's Avatar
it doesnt pop out of any gears,i rencently change the gear oil to motul gear 3000,it made the shifting a little more smooth then it was before,but bascially,you cant feel going into gears like you normally would,like a crunching noise,escpcially third gear,gears dont grind unless its my fault,my clutch isnt slipping,only gets really shoft if i got past 5800 rpms but i rarley,do..........im guessing that this might be a common issue, but the noise isnt coming from the tranny that i can tell of,i can hear it from the shifter itself,i noticed,if i mode it back and fourth in neutral,you can actually feel like its rubbing on something,or maybe lack of grease or oil some place....its werid...my my main issue is that,going into gears.......you can usually feel when going into a gear...but not me,,,,,,,i might change my tranny fluid again,i doubt thats the problem,but im trying to learn how the shifter itself is connected to the tranny so i can see what actually moves the shifter into the gears,
XirtaXa
24
Jan 14, 2025 03:49 PM
XDC
Feb 1, 2015 11:56 PM
fur_pig
Scion tC 1G ICE & Interior
Jan 27, 2015 12:52 PM
VCUBoy714
Jan 5, 2015 08:46 PM
carid
Dec 16, 2014 09:53 AM
