compression test how to? doing this right now..
I bought the compression test device from kragen auto, though I wanted to know if anyone knows the proper way to do a compression check on an xb
thanks in advance
oh and what are teh specs I am looking for?
thanks in advance
In general you disable the fuel pump and or ignition, set the parking brake, chulk the wheels and jam the throttle open. You unscrew the spark plug, screw in the tester and crank it 4 cranks or the needle bobs 4 times.
Thats what basically your cylinder psi is. Second test to see if there is ring damage is to squirt some oil in the cylinder and retest it. If it goes up, the engine has ring wear and needs to be rebuilt, if its the same and low, the valves need adjusting.
I think around 150psi is fine. Anything below 80psi, it needs to be rebuilt. If its low for one or two joint cylinder, you got a blown headgasket.
Its not rocket surgery, the guage should of come with a manual.
Originally Posted by silverevo05
man I have dial up
it'll take me about 2 hours to see that vid
are ther any how to's anywhere
thanks
thanks
Do I disable the ignition or fuel pump
what fuse - theres one #8 the starter system and there are many mulyiport fuel injection #5 7 18 and 30
I know its not rocket science but I dont want to mess it up
I tried search
I'm doing this now so the quicker the better thanks
I tried search
it also says to disable the ignition system
and I only find the efi #5 fuse where is the relay
on the owners manual it says that # 5 7 18 and 30 are also multiport fuel injection system
so do I unplug all of them? doesnt sound right
Standard compression: 213psi
Minimum compression: 156psi
Max difference between cylinders: 14psi
Disconnecting coils is another way to disable ignition.
Take all the plugs out, screw in the tester, floor the trottle and crank the engine. Watch the gauge, usually 5-7 revolutions is enough to obtain the max reading.
I no longer own an xa, however if its silver and from a dealer in richmond, I already messed up the engine.
Anyhoo, its in a box under the hood near the battery, inside the cover it says what the fuses are for, one should say efi. Unplug that, Dont bother with the coils other than plugging your plug back into the one for the cylinder you are testing and touch that to the engine block, valve cover, etc.
Either way, you need to cut off the ignition or fuel, not necessarly both. This way when you crank it wont start and lets you do the test properly.
Ok, cant find the fuse? Unplug all spark plugs and do it that way. May want to head to an advance auto or auto zone in your area for some help, its easy to do a compression test and in their parking lot.
