Differential Drain Plug on automatic transmission..
I have a 2005 Scion xB stock with automatic transmission it has 118K miles.. I recently changed the tranny fluid, and noticed that there
is a what looks like a drain plug located horizontally on the bottom of the differential part of the trans, behind the trans pan.
Is this to drain the differential also? how would I refill the differential if I did drain it? Also what type of oil does it take?
I can find no info on this in the manual.
Any info would be appreciated.
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Dec 26, 2020 at 09:25 AM. Reason: Moved to Correct Forum by Administrator
my manual says Fluid type: Toyota Genuine ATF TYPE T-IV Standard capacity: 2.9 liters (3.1 US qts, 2.6 Imp. qts)
I couldn't find anything about another drain for the differential. I know the 5spd doesn't have it.
aryakshatriya
Jun 22, 2005 10:26 PM
