Exhaust getting really loud overnight?
I have an Precision Muffler auto axelback installed and everything has been running great. The exhaust note has been a good balance between loud and subdued. But this morning I get in my car and it's really alot louder. Anybody ever have this happen?
Note: The exhaust is only about 3-4 months old and the car only has 3000 miles on it so I don't think the exhaust somehow burned out from sitting in the driveway overnight.
If it is extremely loud check the exhaust clamp where the axleback goes to the OEM piping. Worse case scenario get in touch with Stylis on SL here and see what he can tell you about it. Hell he probably built the damn thing lol. Honestly though, I think you either have an exhaust leak or it's breaking in like everyone says.
Yeh- check for an exhaust leak. It really shouldn't get louder suddenly unless something has gone wrong- loose clamp, cracked weld, something like that.
As the exhaust cools, it moves around a little, revealing hidden problems... Glass pack mufflers do get louder over time, but not suddenly- it's why I don't buy 'em...
Originally Posted by iKevin
I have an Precision Muffler auto axelback installed... this morning I get in my car and it's really alot louder.... The exhaust is only about 3-4 months old and the car only has 3000 miles on it...
Checked for exhaust leak last night and all was well. After listening to it, it appears that it's probably just either that the exhaust has just broken in or the engine. Because I also noticed that it appears to have a little more power.
Keep in mind, your exhaust will be more vivid and louder sounding during night and morning times because of atmospheric conditions and less people being out (meaning more noise to be heard) by your car and in your situation, your exhaust. It is just basic physics, less absorbing materials such as less reflection of sounds running into other sounds. The other variables are what people mentioned above. I had an exhaust leak at my manifold/engine area and you will know in that area. It sound like a lawn mower putting and you can smell exhaust fumes really well. I got really lucky because it did not melt the manifold on my engine.
Originally Posted by Avodka14
... I had an exhaust leak at my manifold/engine area... I got really lucky because it did not melt the manifold on my engine.
As the header mates with the motor an unsecured manifold can cause hot exhaust fumes to melt the exposed engine where the exhaust should be directly vacummed. Come on now, that is common sense
hot exhaust under pressure, from a small leak acts just like a welding torch,propane torch and/or a bunson burner. it will melt it away, metal,plastic, paint, anything in the flames path.
What do you think the aftermarket headers are designed for then? They act as a pseudovacuum as to suck air out of the motor or decrease pressure. I agree, the air going into and out of the motor is a pressure gradient and that is exactly how turbos work (exhaust pressure). Anyways, my terminology was not exact above. Do you know how hot exahust temperatures get? They can get up to 1200 F and that has been known to damage pistons and in my previous scenario the heads on the engine if I did not replace my head gaskets and my header as it MELTED SLIGHTLY made the exhaust leak worse! Not trying to start beef just wanted to justify that I am not going to be patronized when I know what I am talking about. No hard feelings bro.
Technically there is no such thing as suction just a lack of pressure. If by vacuumed you mean moving from the high pressure of the exhaust to the low pressure of the atmosphere your first statement is 100% correct as Exhaust to atmosphere = high to low pressure area = in a sense a "vacuum"
As the header mates with the motor an unsecured manifold can cause hot exhaust fumes to melt the exposed engine where the exhaust should be directly vacummed.... that is common sense
