Getting car out of emergency mode?
So I've been having some issues w/my MAF and the check engine lights going off an on. I'm getting P0103, P0012, & P01010, so 2 for the MAF and one for the cam shaft position.
I got my clutch replaced 2 weeks ago, and after that my car started going into limp mode/emergency mode and it won't go over 3000 RPMs. I've read a lot about WHY it happens and what to do to troubleshoot and fix it. I'm going to put my stock intake back in this weekend... it's a brand new MAF sensor... but after using two OBD machines (I work for a company who makes them) and trying several state softwares... I could clear two codes, but the MAF position error is still there and car stuck in emergency mode. Even w/a scantool the code wouldn't clear.
Any one have tips on how to get car back to normal? I'm thinking pulling ECU fuses or unplugging battery for awhile, but I think the code will just come back/car in emergency mode again. As far as troubleshooting, after I put my stock intake back I'm going to see what happens, and if that doesn't work maybe replace the ECU (I heard it wasn't that hard) and go from there.
Any ideas or advice? Help me make my car go over 3000 RPMs again!!! I'm sick of doing 55 in the slow lane haha
you may have a bad cam position sensor, lots of people had that particular issue..
could be a bad maf wire, woudn't really have anything to do with the clutch in my opinion..
pull the ecu fuse, and run it for 10 min, drive around the block and let the system run its checks, and see if they all come back, or if you get less codes..
You said it all started when you had a clutch job?
Check all your wiring harnesses in that area , they may have pinched , pulled or molested the harness in such a way as to break a wire or connection. They needed to pull the harness out of the way to do it so anything could have happened then.
TheTripleC
Jan 4, 2015 06:46 PM
Dmscomp8892
Scion tC 2G ICE & Interior
Nov 22, 2014 02:55 AM
