Help..Overheating, replace just about everything..
Okay so I’ve worked on this car for the past month.
I have replaced the following:
-Water pump
-Thermostat
-Thermostat housing
-Thermostat gasket
-Coolant temp sensor
-Serpentine belts (2) ACC & Main
-Cooling fan
-Fan relay & fusses
-Inspected and tested all electrical
-Flushed and tested radiator for restrictions (internal & external)
-Flushed & tested heater core for restrictions (internal and external)
-Flushed and tested block for restrictions & hoses
-Idle air control valve(leaking coolant into intake) replace valve
I can not figure out what is going on. As of now I have a misfire in cylinder 3, coil packs are good (used meter)
Plugs are good and to specifications, fuel injectors and pump are operating properly.
The engine will start to over heat after about 3-4hrs of drive time.
When I inspected the engine I found:
A. Coolant in the intake
B. Low coolant levels
I found no coolant in the oil. I found no external leaks.
Is this a Head gasket problem? What do you think?
Sticky How To Advanced Search SL (Scion Life)
______________________________
-Water pump
-Thermostat
-Thermostat housing
-Thermostat gasket
-Cooling fan
-Fan relay & fusses
Last edited by MR_LUV; Feb 15, 2020 at 11:16 AM. Reason: Moved to Correct Forum by Administrator
xr1ckx
Feb 16, 2018 03:43 PM
