Help..P0172 and O2 Sensor..hard one..
Help. 2006 Scion xB RS 4.0 1.5L automatic 179k miles gas smell P0172 system too lean Bank 1 comes up on scanner as pending so you go about 60 miles before the light will come out saying P0133 O2 circuit slow response Bank 1 sensor 1 its had all injectors replaced 1 coil cause the previous owner said it had Cylinder 4 misfire and then all this starting happening he's done cat back OEM reg exhaust cat seems fine so ready live data I don't know how to read but a mechanic said its all reading right for most part. So here's the deal starts fine revs up down no issue idle is OK and its only every other time you go to take off and it like hesitates for a sec and then its good to go drives normal full power. I tried 2 O2 sensors in Bank 1 yet still throws the code slow response tried MAF and no difference so put old one on cleaned it with computer duster temp sensor plugs B12 Chemtool in the intake and in the tank and checked for vacuum leaks all looks good tried spraying starting fluid around intake and no difference to see if it was leaking I don't have much money left so I have put on a spark plug fouler for now and had that all put on just to try and get it to pass NYS inspection. I smell it running rich and just 50 miles on a new O2 sensor and its pure black must be from running rich. Help please.
____ |
Sounds like a thorough examination. P0172 is actually system too rich.
Since you didn't mention it, did you get a chance to check the air filter? Here's a pretty good set of instructions to check and or test your oxygen sensor and air fuel ratio sensor. It's not vehicle specific but the theory is easy to comprehend. https://repairpal.com/obd-ii-code-p0133 |
Originally Posted by 62Fender
(Post 4296171)
Sounds like a thorough examination. P0172 is actually system too rich. Since you didn't mention it, did you get a chance to check the air filter?
Here's a pretty good set of instructions to check and or test your oxygen sensor and air fuel ratio sensor. It's not vehicle specific but the theory is easy to comprehend. https://repairpal.com/obd-ii-code-p0133 ____ |
I struggled with P0171 which is System Too Lean. I changed injectors, fuel pump, intake gasket, and checked for vacuum leaks. Nothing worked. I bought new MAF sensor and that didn't work either.
I ended up cleaning my old MAF sensor and reinstalling and that finally did the trick. By the end of it all I thoroughly cleaned the MAF sensor twice. Just my experience but perhaps our sensors are temperamental. ____ |
Originally Posted by celicaboy87
(Post 4296181)
Yes, tried that too. I just can't catch a break. I'm thinking maybe the injectors the guy put in were wrong but don't know how many Psi it should be running at the fuel pressure.
____ If the injectors are suspect, consider asking the guy which injectors he installed. If you can get a part number, Google it for compatibility with your specific car. I'm not saying the guy's suspect however everybody makes mistakes. ____ |
You need to scan and post what the long term fuel trim is at (for idle and 2000RPM if possible) P0172 is triggered around +20%
Too rich fuel-to-air ratio. Your oxygen sensor is reporting this and you can smell gas so there is no arguing with the computer on this point. Possible reasons for this:
OP, did you ever get this sorted out? I am having a real similar issue and really struggling to get it straight. P0172, System too rich. Car bogs, stutters when attempting to accelerate from a stop. But it's seemingly random, sometimes it'll take off just fine. I've checked the air filter, changes plugs, cleaned the MAF & changed injectors.
Deleted
Originally Posted by jferg
(Post 4334672)
Hey all, I got a tip that worked awesome. seems the TCS gets stuck in a weird loop, turn it off for a few miles. mine turned back on again when I restarted the car no problems since. About 2000 miles still running great.
