how to properly store an engine for several years
Old Feb 25, 2009 | 02:07 AM
boxman27's Avatar
Default how to properly store an engine for several years
so i have purchased a back up engine for the box and want to stash it for future use. what should i do if anything to it before it goes into hibernation? i live in so cal so mild weather. it will be wrapped in shrink wrap and covered with whatever i can find old blanket or beach towel.
Old Feb 25, 2009 | 02:13 AM
draxcaliber's Avatar
there is a stickie about storing a car in the maintenance section. basically make sure everything is as clean as possible, disconnect everything, drain all fluids, and plug up all the holes to prevent anything from taking up residence in there.
Old Feb 25, 2009 | 03:12 AM
boxman27's Avatar
sounds good to me. there shouldnt be any issues with the cylinders i guess because they are sealed and the crank journal and bearing will still have oil on them as will the cams lifters ect.ect. just realy wanted someone to back up what i thought thanks
Old Feb 26, 2009 | 10:31 PM
itsme's Avatar
make sure no air/moisture gets into the the head cuzz rust will start to develope around the cam lobs and on the inside of the valve cover....
Old Feb 27, 2009 | 12:34 AM
jct's Avatar
jct
you can always pour some oil down the spark plug holes into the cylinders
Old Mar 1, 2009 | 04:08 PM
boxman27's Avatar
it might not be a bad idea to pop off the valve cover and spray some pb blaster or similar product all over if the cams can be an issue. same with the cylinders i guess i think oil would just run down the side and not actualy cover much
Old Mar 17, 2009 | 03:05 AM
Mattism78's Avatar
You need to add some type of cylinder treatment. A friend of mine had a motor built for his mustang, wrecked the car, and then the motor ended up sitting for a couple years. He pulled it out to use on another project and the rings had seized to the block. He ended up having to get the cylinders re-honed and had to purchase a new set of rings.
Old Mar 17, 2009 | 03:09 AM
davedavetC's Avatar
dont use PB Blaster, its a penatrating oil, use WD-40 which is a lubricant, theres a difference, PB doesnt protect where WD does. just an FYI
Old Mar 26, 2009 | 11:10 AM
jct's Avatar
jct
oil fogger spray stuff into the cylinders thats what i was thinking of...
Old Mar 28, 2009 | 09:14 PM
bB2NER's Avatar
Music City Scions
WD40 evaporates. Fog the cylinders with boat motor fogging oil and I'd also pull the cams so you don't have any open valves or compressed valve springs. Also tape up all the intake and exhaust ports with duct tape before shrink wrapping.
archael666
Mar 19, 2019 11:52 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
ScionLife Editor
Nov 25, 2014 03:00 PM
