Manual Transmission Question: Neutral or 1st while stopped?
You guys are all nuts. You can use the clutch to engine brake a million times and the wear is incrimental at best.
Seriously, if you are approaching a stop light and are throwing the car into neautral well before you completely stop, you're wearing out brake pads before you're preventing wear on your clutch.
I have only owned three vehicles with an automatic and I drive 48k miles a year on average. I use the engine for braking and let's just say, I've never replaced a clutch at all.
Putting it in Neutral at a stop light is a waste...
This whole input shaft and being lubricated is a joke. The oil doesn't fall right off and dry up after holding the clutch in for a few minutes. It stays plenty lubricated to work fine. For the input shaft to wear prematurely would require severe wear and tear. You'll seriously replace the clutch before you'll have issues with the input shaft...
Ugh...
Ugh...
hm ... my practice is ... i actually drop it into neutral when Im decelerating coming up to a stop light and even when I'm exiting the hgihway on a straight away. The only time I decelerate in gear on the highway is coming around a clover or hairpin. If I come up to a green light, shift to 3rd or 2nd according to speed and drive right through.
Now going up hill ... f* that. I'm typically too concerned I might kill the engine to even try. I'll either go around, or slow down and keep rolling in hopes it turns green by the time I get up there lol
edit: and to clarify ... I don't go into neutral to save wear or tear on anything. I'm just lazy
I completely agree with lizard1. When @ a complete stop, it makes no mechanical difference if your in "N w/clutch out" or "1st w/clutch in".
BTW- There is no need for most of us to "performance drive" but rolling a quarter mile in neutral while approaching a traffic signal is plain amatuerish.
* The gas savings are negligable, (stop-n-go traffic for long periods of time notwithstanding)
* If you suddenly had the need to accelerate, (or the more appropriate term, take back control over your vehicle) which gear are you gonna throw it in? More then half the time you will probably make the wrong choice & over-rev or bog.
* While joe-auto-transmission is applying the brakes through a corner, Mr. manual has downshifted and is actually accelerating through it all the while maintaining MORE control.
People should learn how to drive a manual tranny correctly & this includes downshifting.
Thank you, jDub 68. I'm always downshifting as as I approach a stop, finally going into 1st as I do so...
If anything, it takes less gas than coasting in neutral, since the EFI cuts the fuel flow entirely when your foot is off the accelerator and rpms are above idle... not to mention that you're more in control...
You don't understand what I am saying about using the engine as a brake, either. Down shifting for inclines, corners, stops, etc. are what you NEED to be doing when driving a stick.
From the sounds of many on here, you all should have bought autos. Especially the whole "I'm too lazy" crap.
Here's a good question - when you guys are coming off an interstate and doing 70-75mph and come up to a clover leaf, what do you do? Do you down shift? Do you just apply brakes early and get down to a slow speed for the entrance and drop it into 3rd gear and basically coast around the clover? Do you approach the clover at speed, down shift a couple of gears and use the clutch to slow you down with little use of brakes and continue through the clover?
I'd be interested in the responses... I think I'd want to NOT be behind most of you coming from a 70 mph freeway onto a clover leaf, but we'll see...
Got my learners permit in'86. I was driving an early 70's VW bug at the time. Those where the days, Feet on all three pedals simultaniously to keep from stalling, bump starting in reverse by yourself, starting it in gear while parked in the garage, thus destroying my parents washer & dryer.
Yeah, I'd consider myself experienced.
Ugh...
Ugh...
So how do you think I get 40 to 50 mpg in my xB?
rookies still....
Geez I woulld gladly trade cheap break dollars for expensive engine and clutch wear dollars
when costing to a stup in nutral you can always double clutch and go into the proper gear but why would sit at light at a light with your foot on the clutch???
do also you ride your brake in case you may have to stop
now going down a steep inlcine and can see downshifting and using your engine to brake ..like truckers do but this would be on a rare occasion
jDub_68, You too! I've had about 10 VW's... bugs and busses. If you didn't know (or learn fast) how to drive stick, you were screwed! Four wheel drum brakes taught me the importance of downshifting.... 48hsp in a van taught me how to shift on a hill!
I doubt sitting at a light with the clutch in will harm anything. It just gives you a tired leg, and makes you more anxious to get going. My Xb's clutch is very light compared to trucks, and performance cars I've owned. I still sit in Nuetral, though.
rookies still....
Most of the highways in RI are 55 mph - it's a small state and in Newport the maximum speed is the 30mph on ramp to the bridge - the rest of the city is 25mph. The highest speed on the island is 45mph and that is 10 miles from here. We have highways over grown with trees, wet leaves and construction workers so you can't go flying into blind turns safely.
Those 30 mph signs are cautionary "suggested" speeds. It's kinda like any other state (RI has an Interstate, as well...) with an Interstate. The clover suggested speed is 25 mph. However, it is when you decide to shut it down that causes issue.
If you see the sign, believe that you only need to go 25 mph and decide to pile on the braking (While in Neautral apparently) is what is a safety issue.
If the ramp is 25 mph, on a dry day at decent temps, you can easily go down to 55 or 45 and gradually slow while downshifting to help with a semi rapid decrease in speed. Merge safely and teh flow of traffic is not hindered.
What am i doing arguing over basic driving skills? I'm outta here!
