My Box Is Vibrating :( Help!
Old Oct 12, 2010 | 06:36 AM
candyboysince87's Avatar
Unhappy My Box Is Vibrating :( Help!
Any ideas why? I thought it was my air intake, so I went ahead and replaced it with a cold air intake, but instead of fixing the problem it increased the vibrations. What should I do? Any thoughts?
Thanks Guys.
BTW, My car is an '06 XB with 94k miles.
Old Oct 12, 2010 | 11:55 AM
Improbcat's Avatar
Does it vibrate at idle? only when moving? When in park/neutral? Only in gear?
Old Oct 12, 2010 | 02:25 PM
It vibrates a little when it's in park.. But it vibrates more when it's in drive and the most when in reverse. It doesn't vibrate when driving tho. Any clue?
Old Oct 12, 2010 | 04:31 PM
Improbcat's Avatar
My first thought is to have your motor mounts checked. If reverse is the worst it is probably the rear mount that is bad.
Old Oct 12, 2010 | 04:38 PM
Where should I go for that and how much do u think it'll cost me to get that done?
Old Oct 12, 2010 | 08:14 PM
VIP_CAMO's Avatar
Big Sky Scion
Was going to say the same check those mounts.Pop the hood and have someone look to see if the engine moves as you switch from d,reverse etc were the mounts are
Old Oct 14, 2010 | 05:34 PM
thanks guys, im gonna go check it out tonight. Is there anybody know a good repair shop out here in LA? or would it be best to go to a scion dealership?
Old Oct 15, 2010 | 04:23 PM
mwolfe25's Avatar
Did you figure out if it was an engine mount or not? Was the vibration a metal on metal sound or was it the whole car?
Old Oct 15, 2010 | 04:46 PM
Big_Bird's Avatar
Sounds just like mine. It is probably the motor mounts. It is on my list of things to do, but I don;t have the time, resources or money yet.
Old Oct 15, 2010 | 07:45 PM
me too, no time and money.. but i called a scion dealership and ask about my problem, they said that most likeley i just need a tune up since i have over 90k miles in it. they were saying that my sparkplugs might need to be changed and maybe the fuel injector too. i asked if bad motor mounts would have caused it and they said its a possiblity but rare to happen for an xb since xb have pretty good mounts and light engine.
also, i have been noticing that after driving for awhile my car vibrates a lilttle less. Do u guys think its a sign of a bad motor mounts also?
Old Oct 15, 2010 | 07:48 PM
i havent figure it out yet, still with theories. i dont hear any metal to metal sounds though, my whole car is vibrating. Any ideas?
Old Oct 15, 2010 | 08:05 PM
mwolfe25's Avatar
I had a van once that the heat shield on the exhaust would vibrate only while it was in gear. So since the whole car is vibrating then i would say your best bet is to start on checking the mounts first then look at that tune up.
Old Oct 16, 2010 | 12:21 AM
Will do.. Thanks a lot guys, I'll keep u guys posted with what happens.. I'm gonna check out the mounts first then if that doesn't fix then tune up hopefully that does the trick.. Fingers cross!
Old Oct 16, 2010 | 06:06 AM
Zman's Avatar
The VVTI motor vibrates a lot anyway when you're stopped but in Drive.
Good spark plugs help for sure.
Old Oct 16, 2010 | 08:01 AM
VIP_CAMO's Avatar
Big Sky Scion
Well if its not the mounts at least the tune up wont break you to help find the issue.Should spend no more than 10bucks on set plugs.
Old Oct 16, 2010 | 08:43 AM
I got a set of NGK V-power copper plugs earlier today.. I will find out on Monday wether it's the mounts or tune up.. Any other plugs out there u guys might want to recommend me
using instead?
Old Oct 18, 2010 | 11:51 PM
05TXFM's Avatar
I would also clean the throttle body, it helps a rough idle.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
prescottn
Sep 22, 2015 01:30 PM
spharr62
Sep 20, 2015 01:44 AM
mikeac
Sep 15, 2015 03:24 PM
