New product from Power Enterprise
I just received an email from Power Enterprise about a new product that will interest some: www.powerenterpriseusa.net The unit is a Toyota VVTi controller that works in conjunction with your stock ECU.
I'm old school don't really know all the benefits of this item, so if anyone with any techincal expertise can shed some light on this, I'd appreciate it. I understand the basic idea here - to override your stock ECU, but how much does one think can be gained from a product like this in conjunction with a CAI, exhaust, & header? What's it worth?
Thanks all,
David -
Thanks all,
David -
As far as I can tell......no, it's not a fuel management system. It is a system that allows YOU to manually control the VVTi (variable valve timing).....basically overriding the ECU that would otherwise do it for you. That's just my understanding.
KiL
KiL
Originally Posted by 05_camo_boxb
just checked the link....i want one....how much.....do i hear group buy??
OK, I just got a reply from Power Enterprise. For simplicity I will just post the exchange of email:
Thanks for the info. Sorry your supercharger will not work on the XA, I've heard nothing but praise for it. Guess I'll have to look at the Blitz (my appologies). About this CamCon unit: Is this something I could expect to use on my XA? Sorry, but I have to plead ignorance about these things, old school, you know? What kind of gains could I expect to see with my current set-up: AEM intake, TRD exhaust, Alphawerks header? And/or, with the addition of a Blitz SC? Lastly, what kind of price range are we talking about?
I'm not looking to extract every last ounce of power out of this thing - been there, done that. I'm just looking for reliable gains in HP to keep this thing fun to drive. If I could get enough out of your CamCon unit, I might just pass on the Blitz.
Any help/feedback would be greatly appreciated.
Thanks again,
David -
Hi David,
It all depends on whether you are looking to go forced induction or all motor. If you want major horsepower gains and do not mind going turbo/super charged then that is the way you will get the most power out of your car. If you do want to keep the car N/A just for reliability or you would just rather have the N/A feel and response then the CamCon would be a great addition to what you currently have on your vehicle. The unit has not been released at the present however using our working test model we have seen 9~11 hp gains on a stock Celica GT-S and a great torque bump on the bottom end of the power band. We are aiming the price to be competitive with the A’PEX V-AFC unit.
Thank you,
Power Enterprise USA Inc.
17155 Von Karman Ave Ste 108
Irvine, Ca 92614
Tel:949-752-0645
Fax:949-752-0646
Thanks again,
David -
Hi David,
Thank you,
Irvine, Ca 92614
Tel:949-752-0645
Fax:949-752-0646
Here's a little more updated info:
Hello David,
The CamCon unit will be spliced into your existing wire harness for your ECU. For the best results you would need to Dyno tune the car and find out what settings are best for your applications. The simplest way is to run the car various degrees of cam timing and overlap the dyno sheets and plot your ideal numbers throughout the RPM. An example would be to run the car with the cam timing at -5 degrees throughout the entire RPM range and then again at 0 degrees, +5 degrees. You would then have a chart of what power the car made at what RPM for those 3 degrees of timing. Overlay the charts and you can see where the greatest gains of power were on any given RPM and at which degree of timing. Plot those numbers into the CamCon unit and the setting would be complete. To get the maximum amount of power you can take advantage of the air/fuel setting built into the CamCon unit to match the fuel to the newly found power you would gain.
Thanks,
Irvine, Ca 92614
Tel:949-752-0645
Fax:949-752-0646
Hello David,
Thanks,
Irvine, Ca 92614
Tel:949-752-0645
Fax:949-752-0646
Originally Posted by dgHotLava
Originally Posted by unlmtdndeavor
we'll see how much more power we can squeeze out of this motor with tuning. whose gonna be the guinne pig
