P0117? Changed Engine Coolant Temp Sensor but Code Still Show up..
Old Dec 17, 2020 | 06:04 AM
BraddaEdz's Avatar
Default P0117? Changed Engine Coolant Temp Sensor but Code Still Show up..
05 xB.
_____
Old Dec 18, 2020 | 01:41 PM
mrrcom's Avatar
Originally Posted by BraddaEdz
05 Xb
Did you clear it out and it comes back still? or did you replace it and it hasn't turned off? Did you top off the coolant after the change?
Old Dec 18, 2020 | 04:15 PM
BraddaEdz's Avatar
Default Re:P0117? Changed Engine Coolant Temp Sensor but Code Still Show up
I Replaced ECT Sensor, Radiator, Thermosat, and Hoses. Still Overheating🤷‍♂️
and I can hear fan running nonstop while I'm driving, but this time the Radiator light is Not Blinking at all🤷‍♂️
____
Old Dec 19, 2020 | 12:33 PM
mrrcom's Avatar
____
Hmm maybe the thermostat isnt opening. You can test yours by putting it water and bring it to a boil you can see it open up. Maybe you put it in backwards? I can't remember if that possible. Is the water pump area crusty?
Old Dec 19, 2020 | 01:54 PM
2stroked's Avatar
This is a definite possibility. You can have the correct amount of the proper coolant, a perfect radiator and heater core, a functioning thermostat and if the coolant isn't flowing, nothing is going to cool. The OEM water pumps generally last 100,000 miles or so. It's also a pretty easy part to change out. Do yourself a favor though, get a decent quality (OEM is best) replacement pump if it is bad.
To see if it's the water pump, get the car warm, then (gently) touch the upper and lower radiator hoses. The upper should be hot and the lower should be cool. Both heater hoses should be hot.
chabruce
Aug 14, 2015 03:25 PM
Araygoza100
Jul 18, 2015 05:53 PM
danny662boy
May 6, 2015 01:03 AM
Rydrdg
Feb 1, 2009 12:36 AM
violent_b
Mar 12, 2007 02:20 PM
