putting in a set of gauges 06 xb
Old Apr 11, 2009 | 04:34 PM
marcofry's Avatar
Default putting in a set of gauges 06 xb
I've decided to keep the ole xb until it quits, so I have decided to put a couple of gauges in. I've got a couple of questions......
1.
Are the threads on the oil pressure switch npt or bspt on an 06 scion xb...there doesn't seem to be a gasket so I'm assuming npt?
2.
I see a spout/drain on the engine block between the engine and the firewall.I think this is a block drain for coolant. Is this correct and would it be a good spot for temp gauge??
Just trying to get some advance info because this car is a daily driver and I don't want to be stuck waiting on adapters or fittings.
Old Apr 11, 2009 | 05:03 PM
swartzautoman's Avatar
im not to sure about your 2 qustions.
i installed 3 gauges oil press. oil temp and voltage
i ran the oil temp and oil press off an oil filter adapter, it was all real simple.
Old Apr 12, 2009 | 05:09 AM
marcofry's Avatar
I'm not too crazy about the filter blocks. I'm wanting to put a tee in at the pressure switch and run a 3an hose up to the sender.
Old Apr 13, 2009 | 07:59 PM
Peej's Avatar
If you check xbsite.com I've done a fairly intense DIY on 3 gauge install, including the oil pressure switch.
Old Apr 13, 2009 | 09:39 PM
towely............. you somethin elts peej
Old Apr 14, 2009 | 03:51 AM
marcofry's Avatar
thanks peej, it looks like you did pretty much what I was planning with the oil pressure sender......so the block has bspt. any thoughts about the plug/spout in back of the engine for the temp sender???
Old Apr 21, 2009 | 01:40 PM
marcofry's Avatar
small..er...problem with getting the spout off the block..It is really frozen could not get it out..ended up slightly rounding it off..
Oh well, does anyone know the ID of the upper coolant hose?? Looks like I'm going with the inline adapter...
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
my06tc
Jun 25, 2015 12:18 AM
TheTripleC
Jan 4, 2015 06:46 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
mattjk
121
Dec 22, 2004 10:49 AM
