Scion xB front brake issue
I have a Scion xB 2005. the front driver side caliper (wheel) is locked up. this side do not release the pressure.
I replace the caliper and the hose, but the problem continue.
another test that I made ,I switch the two front output lines from the ABS unit to know if the problem moved to the right side but the problem do not moved the problem continue on the driver side. I think maybe the problem is the Master Cylinder.
I want to know if someone have an idea of what happen or another think to test
thanks in advance att Raul
scion xb brake issue
I try to replace the ABS
