Silent High Performance Exhaust
Is it possible to to get or make high performance exhaust system but have it be as quiet as stock or quieter? I like to idea of performance and looks but I totally hate that ricer fart sound.
Guest
Posts: n/a
Originally Posted by LavaBox_v1
The problem is if you want performance you need bigger diameter exhaust and a high flow muffler ... that combination does not equal stock sound ...
It also makes a difference which direction the exhaust is aimed - which is why most big trucks aim theirs straight up...
(I remember a friend who had a '69 Dodge Hemi Charger down in Ft. Worth - the exhaust on that thing sounded like a HUGE berserk Electrolux vacuum. No roar or growl, just a massive WHOOOOooooosh.)
Stylis,
I'm just curious,
How quiet/loud is your stylis axleback compared to the tanabe?
Also, how does it compare in power performance?
I bought yours (5-speed version) because it gives some fart on take-off but is quiet at cruising speeds.
I've been happy with it ever since.
I'm just curious,
Guest
Posts: n/a
Originally Posted by Netobox
Stylis,
I'm just curious,
I'm just curious,
I know there are quiet exhaust on the market, but nothing like stock ... The strup exhaust is quiet ... But you won't get a performance exhaust that would sound like stock ...
Ok, I can only give my experience w/ the Tanabe Hypermedallion axleback, and my Magnaflow custom center exit exhaust.
The Magnaflow muffler I used is very similar to the axlebacks I had made up thru Michael's Mufflers for $200 installed. The Magnaflow numbers are 14832, 14814, and 14829. The only diff between the aforementioned three are the tips.
The Tanabe is so quiet at 4k rpm, that I couldn't hear it inside the car w/ the stereo off. No resonating, no nothing. I only heard the air being sucked by the INJEN SR. At 3k rpm w/o load, it was around 78 dB. The Magnaflow set-up was around 83dB+/-.
I also changed out my OEM resonator, and its definitely lower in tone, throatier, and a bit louder.
If not for having a different set-up w/ my exhaust, I would prolly still have the Tanabe axleback on my xB. I have seen the Strup axleback, and will either run that set-up or the Injen set-up once/if I get my xA. Or I may try something else I was thinking about.
I'm not an exhaust expert by any means, just giving my experiences with what worked for me, and what I have now.
Does an exhaust exist for the tC that produces power but is also quiet? Is there anything out there that would work with headers and intake? I currently have the TRD exhaust w/ headers and intake and I'm about ready to throw the stock exhaust back on--the sound is horrible.
I have the TRD exhaust, and it is pretty darn quiet unless you really get on it. I did a db test on it, and the loudest it ever got through all the rpm ranges was 98db. for comparison, my goped with a 23cc weedwacker engine ran at 130db.
The only prob i've had with the TRD is that the donut that goes inbetween the two pieces of pipe kept blowing out, so i had mine permanently welded on, and havent had a prob since.
Guest
Posts: n/a
My cousin Randode tells me Precision is the way to go--I had him call you guys regarding the full cat back system. Have you had a chance to try the cat back out on a tC with headers and intake? If not, would cat back sound just as bad or worse w/ my current setup? What type of gains can be had w/ Precision's axle back? Thanks for your help!
I wasnt talking about back pressure ... but with performance you need bigger diameter piping ... I know loss of back pressure will cause a car to perform worse ... ALL aftermarket exhaust are bigger diameter ...
