Something is not right.....
#41
Have you ever drag raced before? If not your not that doing that bad. You are might have to do more than two passes to figure out the best way to get YOUR car down the track. Best advice I can give is watch the other drivers and learn, abd get more seat time. Your not driveing a rocket so keep that in mind too.
#42
Originally Posted by xBtuner
What I am trying to find out is............. is the Denso IK16 Irridium plug the one I need running boosted?
Because Autozone could not cross reference ANY irridium plugs for my xB. is the IK16 just the size and thread of the plug or the gapping and heat of the plug?
#43
#45
They may not be hot enough......... Would Irridium plugs be the cure? I know that the Blitz manual suggests irridium plugs but I did not know which ones to run in the xB and nor did autozone or Oreily's. Opinions?
A more expensive platinum double gold diamond forged titanium plug does not = better.
TRY ME, go to autozone, find out what heat range our stock plugs are, and pick up a set of AUTOLITE Copper plugs (they are no more than $1.00 a piece) that are 2 heat ranges COLDER and gap them a smidge smaller than stock. Put them in and report back.
My theory is A.) You cannot control the ECU, so find ways to stop it from taking power and B.) If the plugs I suggest do not work, Let me know and I will paypal you the money you spent on them.
-adam[/b]
#51
Well, went to autozone and they were acting stupid and couldn't figure it out. Went to Oreilly's and they dont have a copper plug that is 2 heat ranges colder in stock. They will have them tomorrow for me though. We will see what difference this makes in the next few days or so when I get them in.
So in conclussion we are going with an Autolite Copper Plug gapped at .250mm correct?
Thanks for all the help!
#52
Yeah you can get a feeler gauge or even just use the little round coin deal they have there for 99cents to gap it.. it wont' be as 'exact' but it will be close. What is the stock gap????
If they don't help in any way shape or form, seriously let me know and I'll eat my words and paypal you what you spent on them.
My thoughts are with your blower being smaller having it produce boost is going to be a bit more heat. Not sure what kind of RPM you have the blower running at though. In any case, it's only going to make a lot more heat, thus the incoming air is going to be hotter. You want to find any way you can to stop the motor from predetonating the combustion. I've never had a problem with a closer gapped copper autolite plug when it comes to forced induction on my 13.4 second Bonneville and my 12.9 second Grand Prix. Both run in the 13psi range on autolite 103's (3 ranges colder than stock). 98% of the blown Grand Prix's in the 3800 community run copper autolites.
It's possible that the 3800 just happens to love them but the same principal should apply here. Colder plug takes away a hotspot to reduce detonation and keep as much timing advance available as possible.
BTW, what octane do you run? Just curious.
#56
Team No Limitz
Thats what I meant and didnt feel like editing the post to change it...he knows that I really meant .025 cause I told him the day before to gap it at but the stock gap is between .035-.04
#57
That kind of gap on this compression at that boost level should be fine. I say start at the .035 mark and give it a few runs.. if still not totally satisfied close it down to .030, and .025.
It's going to take some trouble shooting for sure, but you should see a benefit from the autolites right off the bat I bet.. and specially after the motor warms up.
Curious to see the results. They have done wonders in my cars.
#58
So upon looking at the intake manifold they give you with that kit it looks like that might be the ACTUAL cause of your problems. Doesn't seem like the best design for even airflow distribution, looks like the far cylinder's on each end would get a far different intake charge. Even though all the boost builds in that intake, different ammounts of air can make it into diff cylinders.
Just a thought...
Just a thought...
#59
I have spoke with Blitz and I am actually the first person to bring up any problem about the supercharger with them. They say that their xB runs just fine and has never had any problems.........................
#60
Do they have any dyno sheets or time slips? Any indication of just what it is doing to their car?
Also, if you were selling a product and it didn't work very well but you were trying to make money on it, would you tell people that your test vehicles don't work that great either?
I hope that the plugs fix it!!!! Just food for thought is all
