Spark Plug Gap and ING Timing
Old Apr 5, 2009 | 01:40 AM
frogbox's Avatar
Default Spark Plug Gap and ING Timing
Ok folks started this thread to keep all the info in one spot instead of in 3 different threads.
If anyone has a Scan Guage in their car and wants to help with this research here goes. Already got some info from people here, but the more the better
the info needed from the SG is ING timing @ RPMS , auto/manual, Type of plug and what are they gapped at , octane you uses , ethanol ( if above 10%) temp ( air and coolant ).
This is becoming very interesting and you might all be surprised at what I am finding. Soon as I get enough info I will be passing along what I have found.
You can post the info here or PM it to me ( incase your shy )
Old Apr 6, 2009 | 12:08 AM
Sciond's Avatar
ok I will do this tomorrow
Old Apr 7, 2009 | 04:59 AM
Reactor's Avatar
Here is some Scangauge related info: http://www.clubxb.com/forums/f2/scan...ead-25357.html
At idle the timing on mine usually shows as 4BTDC. Accelerating is around 19BTDC. The highest advance i've seen is 38BTDC- on high RPM cruise, very light throttle.
Auto trans BTW.
Old Apr 7, 2009 | 06:20 PM
Reactor's Avatar
And as far as plugs: cheap NGK Copper with factory spec gap (dont remember exact number now).
Old Apr 10, 2009 | 11:00 PM
Snoodge's Avatar
One thing I would like to know is...
Why are people reccomending .044 gapped Iridium plugs and saying to get Denso or NGK Iridiums gapped at .044 when if you go to the Denso website and select 2006 xB Iridium it shows the correct plug as .027?
Is there some advantage to be had with the more aggressive gap?
Old Apr 11, 2009 | 12:52 AM
frogbox's Avatar
If you can wait a couple days I will post up what I have found. Your all going to be surprised , real surprised. It will probably upset a bunch of folks , but the info I got is from you all , and a few of the manufacturers , and SMOG Techs that were kind enough to help .
Old Apr 11, 2009 | 02:18 AM
Sciond's Avatar
5spd manual
Denso iridium gapped .044
Old Apr 12, 2009 | 06:28 PM
frogbox's Avatar
OK here it is....
Its Gone but not forgotten
Old Apr 13, 2009 | 01:06 AM
spr0k3t's Avatar
Thanks for the information frogbox. Sounds like the research was a bit exhaustive tbh.
Old Apr 13, 2009 | 05:05 PM
Sciond's Avatar
interesting read...
did you use indexing on the plugs?
Also just confirms what I have always said.... I hvae almost 90,000 miles on Denso iridium plugs and the only reason I use them is to get longer change intervals since I drive 25,000 plus miles a year.........
No more hp
No more mpg
Dunno how many times I have stated this
but this interesting about Tomas's gap as I always just used the Denso recommended gaps........
Old Apr 13, 2009 | 05:19 PM
Snoodge's Avatar
FrogBox - 1
Fanboys - 0
Old Apr 13, 2009 | 06:07 PM
365Motorwerks's Avatar
Interesting seems reasonable as the computers can fix way more crap than we give them credit for! They work overtime keeping even the most out of spec cars within guidelines. The one thing that I have seen is that a higher quality like Iridium plug will last longer physically where the low end models will start to round off the electrode sooner.
Old Apr 13, 2009 | 07:44 PM
frogbox's Avatar
might as well be forgotten
Old Apr 13, 2009 | 08:54 PM
spr0k3t's Avatar
Originally Posted by frogbox
What's my next project gonns be ? HMMMMMMM.........
The benefit (or lack thereof) in aerodynamics with installing bodykits on the gen1 xB. And, for giving you the idea, I only request that you send me one of the kits you get for suggesting the idea.
Old Apr 13, 2009 | 09:19 PM
Test kits could be constructed out of a certain highly versatile and biodegradable corrugated product. Videos would be required.
Old Apr 13, 2009 | 09:21 PM
frogbox's Avatar
This one has been in the works already :D Any help with the cost of the NASA Wind Tunnel can be sent to me.
An areodynamic brick
Old Apr 13, 2009 | 09:29 PM
Sciond's Avatar
how about sri vs cai
throttle body spacer
how many lick to get to the center of a Tootsie Pop
Old Apr 13, 2009 | 10:07 PM
frogbox's Avatar
Did the throttle body spacer, nobody believed it
SRI vs. CAI been done
Tootsie Pop , my dentist didn't approve, actually he wanted to get more money after.
Old Apr 13, 2009 | 10:49 PM
Sciond's Avatar
the spacer one I missed that....Although just like some folks who " say wow I put in Iridium plugs and can really feel the difference"
Sri vs cai..lots of different choices since done
Old Apr 13, 2009 | 11:14 PM
Ace83's Avatar
Ronin Scion
this is interesting, im doing my complete ignition map on my F/I tc.. right now im like around 39-44 on 2750-3500 rpms, idle is around 18-22 cold start and 14-18 on hot idle depending on intake and coolant temp.. using 2 step colder NGK iridium gapped at 0.034"
my06tc
Jun 25, 2015 12:18 AM
daniinpitt
Apr 4, 2015 08:07 PM
yhwhdesign
Feb 6, 2015 04:58 AM
cid_mcdp
Jan 5, 2015 02:45 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
