supercharger fuel upgrade questions.
Old Jun 17, 2005 | 08:08 PM
Simplyscion's Avatar
Team No Limitz
Originally Posted by lastlookcustoms
You dont need pics of the fuel system. Its just a return line out of the rail into the tank.
About injectors, there are a few places that make them already... Just not advertised for the xB. You can use the Miata injectors from Power Enterprise. Thats what I am using. They are 410cc injectors....
so is there a place to make a return for the fuel? Also does the regulator in the tank get removed? How about the regulator for the rail? What did you use? Where did you put the return line to in the tank?
Also, I believe there is a upgrade fuel pump for the PE, is that drop in?
I drilled a hole in the top of my sending unit and used a bulkhead fitting. There is another room in between the other ports there to drill. Yes, the in tank regulator does get removed. I pulled mine out as my pump was a little taller so it took up the room where the regulator was. The regulator for the rail is going to be aftermarket because there isnt one for the stock setup. Mine is mounted on the passenger side strut tower. I used the aeromotive one with the -6 an fittings. I came out of the Perrin rail which has an outlet port on it, and went to the regulator. From there it goes to the return that you put into the tank.
The PE charger comes with a 130lp/h pump. They also offer a 160 lp/h pump (which is what I am running) which takes a little bit of "making it fit". But I believe the 130 is in fact a drop in unit.
Hows everything goin over there w/ the install...I was gonna come up sunday but I realized it was Fathers day...goin out on the boat for the day w/ the fam. Gimme a shout lemme know how things are so far.
Old Jun 17, 2005 | 11:55 PM
lastlookcustoms's Avatar
Bro, I havent even messed with it since last weekend. I just got the rest of my fittings and my braided line today. I still havent gotten my injectors or fuel pump, but I am gonna run it without it. I hope to have it on the road this weekend....
rain7905643
12
Jun 13, 2018 05:34 AM
anti_virus347
May 28, 2015 06:01 AM
anti_virus347
Apr 3, 2015 05:17 PM
TheTripleC
Jan 4, 2015 06:46 PM
hotroddelux
Dec 3, 2014 11:33 PM
