throw out bearng again!!!
Old Jan 1, 2007 | 05:42 AM
kustom_play's Avatar
Originally Posted by hotbox05
the dealer won't fix it.
it's wear and tear.
if it' bad you hold your clutch in at stoplights and such. quick death to throwout bearings
omg this dude for real?
LOL
Old Jan 1, 2007 | 07:23 AM
jwaj2002's Avatar
TOCC
the only thing that hurts the clutch other then misuse, is leaving your foot on the clutch pedal, and basicly riding the clutch
Old Jan 1, 2007 | 04:18 PM
yea holding in the clutch is like it being in neutral it wont shorten the life of the throwout bearing
Old Jan 1, 2007 | 06:28 PM
hotbox05's Avatar
yes it does. becuase the bearing face is always in contact with the pressure plates springs. eating up the face of teh bearing. and constantly spinning the bearing.
ask anyone....
or think you're rigth when in actuality sorry to say but you are wrong.
Old Jan 1, 2007 | 11:06 PM
dexter_5000's Avatar
they may need to look into your clutch pedal adjustment to make sure its the correct length. it could be engaging a little even though your not engauging it any.
Old Jan 2, 2007 | 12:28 AM
ask anyone....
ohh man
do you even drive stick, i'll post up how a throw up bearing works in a bit. Maybe it will educate you a bit on how clutch systems work.
Old Jan 2, 2007 | 12:32 AM
"Premature wear of the throw-out bearing can occur when there is insufficient clutch play, resulting in a throw-out bearing that spins continuously. If the bearing fails, it may seize and quickly wear the fingers of the pressure plate. The throw-out bearing does not require routine maintenance, but should be replaced when clutch replacement becomes necessary."
http://www.carcare.org/Manual_Transm..._bearing.shtml
read up, your clutch does not engage when your stopped.
its like putting your auto trans in neutral
trust me on this one, i use to race cars, i know how bell housings and clutches work
Old Jan 2, 2007 | 12:33 AM
dude hotbox is right think about it the pressure plate is bolted to the flywhe which is bolted to the crankshaft. those parts never stop moving the only thing thats being disengauged is the clutch friction disc when the pedal is pressed upon. doesn't stop anything from turning thats still bolted to the crank or flywheel. has to rotate on something. a low rpm shouldn't do damage to the throwout bearing as in to wear it out prematurley though either. lots of revving on the other hand could.
Old Jan 2, 2007 | 12:36 AM
ziobep's Avatar
what sound does it make???
Old Jan 2, 2007 | 02:51 AM
DirtyMexican's Avatar
it sounds like a cricket, barely barely touch the clutch and the sound goes away.
thanks everyone for all the post, im sure this thread will help several others in the future as well!!
thanks!
Old Jan 2, 2007 | 04:20 AM
jwaj2002's Avatar
TOCC
just out of curiousity what does it cost to have a clutch replaced at the dealer?
Old Jan 2, 2007 | 04:33 AM
hotbox05's Avatar
yes I do drive a manual transmission car.
and yes holding in the clutch unneccessarily DOES speadily wear out the throwout bearing.
ask someone who works in a transmission shop.
Old Jan 2, 2007 | 04:53 AM
ok i'll go half with you that in theory, yes it does cause wear, but if you have a well designed throw out bearing it wont matter becasue it should be well enough designed that you should be able to replace it out only when the clutch goes bad
unless you drive a lotus, then thats another story
Old Jan 2, 2007 | 05:27 AM
hotbox05's Avatar
lol. lotus's are always "another story"
ha ha
should is always a key word.
my old pos datsun 210 was cheap and old , i held in the clutch all the time ,
my vw bug was cheap and old i i killed a throwout bearing , dunno if it was from me or a previous owner but yeap.
supra's throwout bearing was fine when i changed the clutch
buddy's ford van's throwout went with a guess of about a year left on his clutch.
not holding in the clutch unneccessarily is free insurance .
just like not downshifting for no reason or to stop each and every time helps the clutch live longer.
Old Jan 2, 2007 | 06:04 AM
bB2NER's Avatar
Music City Scions
I agree with hotbox05. Holding the clutch in at lights and such does add wear to the throwout bearing. The bearing is under the most load while the clutch is disengaged.
Old Jan 2, 2007 | 11:18 PM
just got back from the dealership, this is the verdict.......
throwout bearing was in tip top shape, the noise was coming from the fork that engages and disengages the throw out bearing. The lubed it up and all is well.
thanks for making this thread a useful reference for all the SL homiez
Old Jan 2, 2007 | 11:19 PM
hotbox05's Avatar
wow. they did all that labor for you? must be nice to have a dealership who's so nice.
congrats on a fixed problem
Old Jan 3, 2007 | 01:07 AM
jwaj2002's Avatar
TOCC
yea, sounds like you got lucky to get a good dealership with knowledgeable techs
Old Jan 3, 2007 | 02:04 AM
06B0X's Avatar
Originally Posted by DirtyMexican
indeed
Where you taking it??? I got an appt Friday for my 3rd light has stopped working, if they try and pull anything on me, I'm not going to have it.
Old Jan 3, 2007 | 02:14 AM
go to Mike Erdman In Merritt Island and talk to Jon hes the service mgr, he will hook you up, I have never had any issues there.
