Trouble with 2006 Scion xB Release Series..
Hey guys, I joined because I am having THE WORST TIME keeping my car running.
So any ideas of what to do next will be greatly appreciated
Initial Problem:
Car began not wanting to start. Would Take Jumps. Stopped taking jumps.
Been through multiple batteries. Will not hold charge. Always drains to nothing after a few days.
Battery light flickers when braking
Car lights go off at around 60mph
Car starts with jump, charges battery some, turn off, turn back on (immediately) no start
Replacements:
Alternator: No Fix
Push button bypass (car would not turn over with key and still doesn't) : worked for a couple weeks
Starter replaced : No Fix
40 amp fuse: No Fix
Multiple new batteries: No Fix
Current situation: New battery, ignition wont work (push button start), starts with jump, battery begins to drain (or charge whatever it feels like that day), after ignition is cut, will not start again.
Any suggestions?
Sticky How To Advanced Search SL (Scion Life)
______________________________
Initial Problem:
Replacements:
Alternator: No Fix
40 amp fuse: No Fix
Any suggestions?
Last edited by MR_LUV; Feb 7, 2020 at 02:03 PM. Reason: Moved to Correct Forum by Administrator
I'd be looking for a current draw someplace that's draining the battery. Take the positive battery cable off and place a test light or DVM in series between the cable and the battery. See if you've got juice flowing. The first place I'd look is that aftermarket push button start.
What Voltage do you measure while the car is running? Sounds like bad Alternator from all the symptoms but my other idea is a really strong Draw from somewhere like an Amplifier
You can also follow normal Parasitic Draw procedures. You can also measure Amp Drop on the fuses themselves but Google it if you want to get more advanced.
Otherwise I would say you need a Professional Auto Electrician.
_____
_____
blackcherrytc813
9
May 18, 2012 01:30 PM
ecko04
Scion tC 1G ICE & Interior
16
Nov 28, 2009 04:20 PM
dmpsk8
Jul 6, 2008 07:34 PM
