What motor oil do you use?
My box gets pretty gentle usage and I use a Synthetic Blend (Castrol Syntec Blend). During my three "Free" (really, prepaid with the purchase of the vehicle...) oil changes, there was only a $6 surcharge for doing that.
I recommend a synthetic or synthetic blend depending on how hard you make the engine work.
Tom
Tom
Synthetics are a good choice. Keep in mind that they get dirty just like regular oil and should really be changed at the same intervals for this reason. Another important consideration....It is generally not reccommended to put synthetic oils in a new or freshly rebuilt engine...5000 miles use is good rule of thumb before switching to synthetics.
oil question
I use mobile 1 but i have a question .....I have heard if you want to run synthetic after you run normal oil you must first run your engine with synthetic then drain it a put fresh synthetic so you engine coats and lets go of all the old oil? PLease lmk what the truth or what you guys reccomend....Thanks
Re: oil question
That actually makes some sense. Is it absolutely necessary, I don't think so but it would give you very close to 100% synthetic in the crack case instead of mostly synthetic with a little residual regular oil.
Mobil1 Mobil 1 Mobil1 Mobil1 Mobil1 Mobil1 Mobil1 Mobil1 Mobil1 Mobil1
