At what RPM does the VVT-i kick in? I suc at searching!
Old Jul 30, 2006 | 04:12 PM
justdrive's Avatar
Default At what RPM does the VVT-i kick in? I suc at searching!
feels about 5000 rpm,
Old Jul 30, 2006 | 05:16 PM
TRDXA06's Avatar
it sounds like it kicks in a little more like 4000 on mine but i dont no the exact rpm
Old Jul 30, 2006 | 05:27 PM
PunkInDrublic's Avatar
VVT-i does not kick in like v-tec does. Instead it smooths out the powerband for optimal performance, what you are experiencing is the torque peaking.
Old Jul 30, 2006 | 05:48 PM
jct's Avatar
jct
vvt-i is always on; never turns off
Old Jul 30, 2006 | 07:39 PM
dexter_5000's Avatar
it just adjust the intake camshaft via oil pressure and computer sensors. making the duration long or shorter by rotating the cam shaft.
Old Jul 31, 2006 | 08:08 AM
willlangford's Avatar
ya this last weekend on the dyno it felt like 4k for me
Old Jul 31, 2006 | 09:22 AM
SquallLHeart's Avatar
uhh..... just because...
umm.. no...
vvt-i is always running constantly.
Old Jul 31, 2006 | 04:54 PM
hahahahahhaha
Old Jul 31, 2006 | 05:25 PM
TuningIsLife's Avatar
the new hondas have i-vtec so that even they are like VVT-I. Only the VVTL-I has a "kick in" RPM.
Old Aug 1, 2006 | 11:20 AM
mat18's Avatar
what car has the VVTL
Old Aug 1, 2006 | 12:07 PM
DouBLeJ16's Avatar
2ZZ 1.8 engine. in a celica GTS or a lotus elise.
Old Aug 1, 2006 | 06:56 PM
also found in the matrix xrs and corolla xrs models.
Old Aug 1, 2006 | 10:25 PM
bighvyxb's Avatar
vvt-1
varible-valve-timing-intelligence,
self adjusting for optimal fuel economey
Old Aug 1, 2006 | 10:37 PM
mat18's Avatar
I think the VVTL should have been on the XB. I think this would have made the car more fun to drive.
Old Aug 1, 2006 | 10:39 PM
If you can fit the 1.8L Matrix XRS motor in, then be my guest. Got to remember. This was a Japanese car to start. Least they gave us the 1.5L instead of the 1.3L that is offered in Japan. Hell some Toyotas only have a 660cc motor. How about that?
Old Aug 1, 2006 | 10:47 PM
mat18's Avatar
dont they have a bigger liter engine for the BB also.
Old Aug 1, 2006 | 10:54 PM
1.3L or 1.5L
Old Aug 3, 2006 | 02:17 AM
Jhhnn's Avatar
"it just adjust the intake camshaft via oil pressure and computer sensors. making the duration long or shorter by rotating the cam shaft."
Not quite. the duration, the number of degrees of rotation that the valves stay open, doesn't change, but the timing of the fixed duration cycle is altered by as much as 60 degrees, iirc...
There are engines that control both the timing and duration, but not in an xB...
Old Aug 3, 2006 | 02:39 AM
over all its still fewer moving parts than v-tec system. more or less accomplishes the same prinicipal of effect. allowing for more power at top end and more torque in the bottom end. it also saves on some gas effiency as well.
Old Aug 3, 2006 | 07:33 AM
mat18's Avatar
I think the vvti does really good on hills. I can fill the change when going up hill.
