ZPIracing taking delivery of XB on friday
Old Oct 13, 2005 | 12:45 PM
ZPIracing's Avatar
Default ZPIracing taking delivery of XB on friday
ZPIracing is proud to announce that we will be taking delivery of our nex xB this friday. We have been waiting for awhile and it has finally came in.
Why are we telling you this? In the power hungry forum?
Because we are ZPIracing and you know what that means. We will be offering a complete product line directed towards the xB. You can expect similair prouducts to that in our tC line up.
Is there any thing you guys would like to see? Something we should focus on first?
We will be watching the xB forums a lot more now. We are here to learn a little too as this is a brand new platform for us. So any inside info that you all have alreayd figured out that you think we need to know by all means let us know.
Thanks for reading and we look forward to having some fun with the box
Old Oct 13, 2005 | 12:46 PM
Limey's Avatar
This is going to be priceless.
Old Oct 13, 2005 | 01:07 PM
FrankenScion's Avatar
Motor conversion kits.
I think you are very limited as to what you can do with the stock motors.
Old Oct 13, 2005 | 04:42 PM
deviousXA's Avatar
ScionERA
i second what franken said a motor mount/swap kit would be the best thing.....as for the 1nzfe try making a 4-2-1 header only one other company is developing them(MMW)
Old Oct 13, 2005 | 05:33 PM
hotbox05's Avatar
make a swap kit for 1zz.
Old Oct 13, 2005 | 06:31 PM
latinotke639's Avatar
i like the idea of a bad **** stock motor, how about a really good stroker kit, then add a turbo to that, make this baby push out as much as possible
Old Oct 13, 2005 | 06:37 PM
cmdxb's Avatar
swap kit! ala HASport or Sohfast for Hondas
a stage 0 turbo for the box, with boost safe for stock internals!
a safe Supercharger......that is designed for the american xB...
a really nice axel back , designed for Forced Induction
Old Oct 13, 2005 | 06:45 PM
Simplyscion's Avatar
Team No Limitz
a top mounted turbo setup instead of jammed behind the firewall, then a fuel setup thats worthy, possibly cams/rods/pistons, cv joints/axels, etc
killerxromances's Avatar
I personally would like to see:
Turbo option for 1nz motor.
New head package
Stroker kit to a 1.7 or 1.8l
A turbo exhaust system.
Stand alone if possible..
Do what ZPI does best. The 1nz-fe isn't too bad, all the xb needs is in the range of 160-170whp to make it fast given the weight and gearing. When i say fast i don't mean it can beat a sti, i mean fast compared to others in its class thats street driven pretty much daily. "Your average car person" i suppose is what i'm getting at..Eh, whatever, you get my point.
About time!!
Cya
Old Oct 13, 2005 | 07:00 PM
hey zpi, do what you do, i wanna be able to ____ some people off, on the street and at the track
Old Oct 13, 2005 | 07:24 PM
TheScionicMan's Avatar
The offset crank on the 1nz doesn't make it a good candidate for boost from what I've read. Hope you guys can find a solution.
Old Oct 13, 2005 | 07:27 PM
Team No Limitz
I ran boosted for a while w/ no problems and the guy who bought my xB is doing just fine still boosted at 6-7psi daily...Stu(lastlookcustoms) ran fine for a while w/ no problems, Dave(DgHotlava) has the P.E sc and has been running fine for a long time.................................................................................etc
Old Oct 13, 2005 | 09:50 PM
I'd like to see a 8-11psi turbo with the right build up on the bottom and top end.
Old Oct 15, 2005 | 06:30 AM
BoogieQ's Avatar
What has been learned is other than an intake right now, the rest of the mods are useless N/A, pretty obvious that headers on a 1.5L will get you NO gain if not slow you down.
Boost.
Boost.
Boost.
Make sure fuel is up to snuff and release a reliable turbo setup for the xB and I will buy it.
I would like to see an adjustable ignition timing setup, possible ECU rewrites. I am going to contact my brethren in the 3800 world and see if they can work their magic and get us write capability. I have found a scanner that can read ISO so my bases will be covered there.
Boost.
Boost.
That's the only way to get anything decent out of a 1.5L, and I am willing to bet the internals are just fine. Don't replace things that don't need to be replaced!
Old Oct 16, 2005 | 02:21 AM
Boost.
Boost.
Boost.
Boost.
Boost.
I was dyno'd at 104whp @ 4,200rpm on an N/A automatic. Obviously its not completely useless. A rough 14whp gain is pretty average for any 4 cyl. with bolt ons... I get what your saying, we probably wouldn't see major gains off N/A vs. turbo. But, at the same time, the odds of any n/a'd motor getting the same gains a turbo does is pretty slim.. Depending on the size of the turbo obviously.. That makes sense i guess.
Cya
Old Oct 16, 2005 | 03:17 AM
Prototype_xB's Avatar
Old Oct 16, 2005 | 03:49 AM
Romanova's Avatar
ITB setup. This could really make the car a lot more fun to drive. Bump the rev limiter up to 7k and let em sing.
Old Oct 17, 2005 | 12:17 AM
Yes! Hell, raise it a little higher than 7k. I'm used to high revving honda motors, i'd really like to see my redline raised to 7,500-8K if possible. 7k at the very least.
Cya
Old Oct 17, 2005 | 02:03 AM
fusionscion's Avatar
omg zpi i love you now.... please make a awsome turbo for the xB for a reasonable price... lotta power compared to the 84 whp stock and i will be a happy person
Old Oct 17, 2005 | 02:11 AM
Where do you get 84whp from? Just wondering, have you dyno'd yours? The lowest number i've seen dyno'd for a stock xb is 86whp. I've seen as high as 94whp and i've even seen some autos pull in the 90-91whp range.
At any rate, we all want more power! ;)
