|Dezod Motorsports| Energy Suspensions Motor Mount Inserts!
I need better installation pics. Those instructions don't do justice without real under the car pictures. I plan on installing atleast 2 of the mounts and then have the dealership install the other 2. Does anybody have real pictures?
Originally Posted by captdownshift
i used a lift and engine support when doing it (cheating) and had access to a press, they pressed in super easy
Well from what i have read, 2 of the mounts are easier to install than the other 2. I need to install atleast 2 of them to cut the labor cost down. I heard using a jack and a block of wood to help move the engine up helps. If I do get to install 2 of them, I'll take pics and post a DIY. I plan to do it in the next week, but you never know what will come up.
lets put it this way its a lot of work for an improvement. be prepared for more noise in the car. i think it feels so much better even with the noise. at idle your going to have some vibrations in the car too. these are the sacrifices your making to have better mounts.
Originally Posted by paul_dezod
Originally Posted by scion04xb
I have them in my xa they fit fine. Just thought I would throw that out there.
vastly better throttle response, positive shift engagement
to give you an idea of the difference in throttle response, short of headwork, ITB's or forced induction nothing you do will make a bigger difference in throttle response then motormounts
I ordered these a week ago and got the left and right side mounts installed. They were pretty easy to do, and I didn't need a lift or press. I'm working on the rear one, but I'm not sure how to get the bolt out on the old mount since it is so close to the firewall. Any one taht installed them can help me??
P.S. I would have taken pictures of the install, but I don't have a working camera now
^^^ The drivers or passengers side?
Update: I tried it again after buying some stubby wrenches and got the bolt off. I took the bottom three bolts off and the other mounts again so I could lift the engine up. I lifted it as far as it would go, but the studs on the mount were so long, it still couldn't come out, it would just hit the firewall. Do I have to drop whole steering/suspension assembly out or somethin to get the darn thing out? Help plz!!;)
MinusPrevious
15
12-12-2020 06:47 PM
trickedxb
9
01-16-2004 07:34 PM
