2006 xB ECU Wiring....
I've searched but all of the links I've found are years and years old, and no longer work!
Long story short... I dropped my built motor in my 2006 (which I originally purchased all my stuff for my 2005). All the parts will work on my 06, however the ECU wiring is different between the 2.
I bought a standalone AEM EMS from Dezod for my 05... which has the plug & Play harness. I need to move the wires to the correct wiring for the 06.
So... I'm pretty certain that I have the 05 ECU pin out from when I had a supercharger on it back in the day. I can't seem to located the 06 to safe my life. Any help is greatly appreciated!
~Clay
~Clay
It might be in the 06 Service Manual.
I would check CAN Communication, Electrical Wiring Diagram and Engine Control System.
But it might be anywhere in there. Worth a shot if you haven't checked them yet.
They should be on the forum, but if not I can upload the PDF's and link here
I would also like to have this information. It's pretty freaking elusive to say the least. I need the ECU pinout on a 2006 xB. I looked around and acquired a Camcon. The installation would be a cake walk if I knew what wires were what in the ECU connectors.
I've got a little time to keep on searching for that, as I absolutely am not doing this without a wideband installed first.
So if someone here in the F/I section has any sort of information to help a guy out, it would be greatly appreciated.
Thanks in advance
Randall
Thanks in advance
Randall
xjleitex15
Aug 18, 2015 01:23 AM
domincnTC
Aug 4, 2015 01:47 PM
