Anyone tried using an FMU....
This may be something that has already been visited, but I was wondering if anyone has tried using an FMU setup and boosting fuel pressure in reference to boost. The factory ECU may not be as inclined to make the changes it does when a piggyback is used. I apologize if this is an old topic revisited, someone will let me know if it is I am sure.
Team No Limitz
even if you convert over to a return line setup your still gonna be limited to about 55psi max unless you remove the in tank regulator and replace it with something that will allow it to flow...when you pull the regulator out it wont pump fuel...tried that one a while back.
Team No Limitz
the stock regulator is limited to about 45 psi, with the adjustable FPR you can squeeze up to about 55psi. I ran a 255 lph walbro, i actually had to modify the sending unit to fit it, but to answer your question, no it will not pump without the stock regulator or something to block that port off.
Team No Limitz
aright here is the layout for the return line...I put a bulkhead fitting in the sending unit and attached the stainless braided fuel line. Ran that under the car and up into the engine bay to the FPR, then ran the line from the fpr to the end of the perrin fuel rail....as far as the 255 lph, yea its definitely overkill thats for sure.
Team No Limitz
53 psi
