BLITZ Compressor System any good???
Old Jan 20, 2007 | 04:00 PM
  #41
illiST's Avatar
What kind of problems?
Old Jan 20, 2007 | 09:32 PM
  #42
blown_xa's Avatar
well i sheered 3 crank pulley pins because of the extreme pressure the charger puts on the belt drivetrain. plus it's really really hard to prevent the belt from slipping, even with the best belt. You have to keep constant attention to the belt tension. The only thing i wanna open my hood for is to change the oil and clean, I don't wanna have to worry all the time. The Greddy Turbo has been good thus far.
Old Jan 20, 2007 | 10:38 PM
  #43
illiST's Avatar
OEM crank pulley & pins? wow
Old Jan 20, 2007 | 11:54 PM
  #44
blown_xa's Avatar
yea i did it with the oem pulley, and the lightweight one, the best solution I found was to replace the oem roll-pin with a 1/8 inch high quality drill bit ( cut the end off, round end to the same length as the oem pin.)
  #45
blown_xa's Avatar
Old Jan 21, 2007 | 01:00 AM
  #46
illiST's Avatar
Thanks for the info.
Old Jan 22, 2007 | 11:33 PM
  #47
xSTANDxSTRONGx's Avatar
Team XcelsiA
DAMN! thats some tihs I didn't even thing about. How much was the Turbo kit? and how is your milage now?
Old Jan 24, 2007 | 09:36 PM
  #48
Baine's Avatar
25,000 miles on my blitz and no real problems. original belt is just starting to slip.
Old Jan 25, 2007 | 08:00 AM
  #49
Team XcelsiA
^good to hear
Old Jan 25, 2007 | 05:45 PM
  #50
randomsuper's Avatar
what did you have to do to make the turbo kit fit on the xa?
Old Feb 1, 2007 | 03:26 PM
  #51
blown_xa's Avatar
hey do u have a boost gauge connected???? Just trying to help u out here... cause i didnt think my belt was slipping for about 3 months...until i connected a boost gauge and noticed it lost boost as the rpm's went up. It should hold consistant boost all the way to redline.
Old Feb 1, 2007 | 03:28 PM
  #52
blown_xa's Avatar
the difference between your belt slipping and not slipping can be 20hp no joke
Old Feb 1, 2007 | 04:07 PM
  #53
Baine's Avatar
Yes I have a boost gauge. The belt slips and squeals only when the engine is cold.
I have adjusted all that I can and now it's time for a new belt.
Old Feb 9, 2007 | 12:25 AM
  #54
ruben7520's Avatar
I have a Blitz Supercharger Installed on my Scion Xa Currently. it does up the horse power quite a bit and it gives you the option of turning the kit completley off. the only thing is that with adding an extra 3 pulley's that the belt goes through it kinda takes away. also i realized that about every 10,000 miles or so your belt will start to get loose so retightening is needed. all in all it is a good kit and reliable as hell. havent broken down ever and ive driven every weekend 500 miles not including the weekdays to work and back for a year and its still like new!
Old Feb 12, 2007 | 02:25 PM
  #55
firesquare's Avatar
i like the way it looks and the power option is a plus for me.
Old Feb 12, 2007 | 05:57 PM
  #56
bfurches's Avatar
blown xa, please do give us some more info on the greddy turbo kit. I took an rs3 xb in trade with this kit, and while the power was substantially increased, i was very dissapointed in the layout. I hate how all the piping was run over the top of the motor. is it the same in the case of the xa? thanks.
Old Feb 12, 2007 | 11:41 PM
  #57
blown_xa's Avatar
yea because of the confined space i believe that is the easiest way to run the pipes. The kit I have is the same. I like how it looks in my opinion though. You can paint or powdercoat the pipes , chrome them perhaps...
I don't have any real pics yet, but if you click on my avitar, it will bring you to my dealer's website, on the main page (scroll down) is a recent pic of my car on the dyno with hood open, u can see the piping from side angle.
Old Feb 22, 2007 | 04:57 AM
  #58
WANABOX's Avatar
i have a blitz sc and have had a bad problem with hessitations and dynoed out at 110 hp.
as of now i have had it 4 5 months and am not satisfied. but have found new hope with this web site with putting stock tc injecters in my xb. but i need the injecters.
Old Feb 23, 2007 | 05:19 AM
  #59
WANABOX's Avatar
does any body know what to do about the massive lean condition with my blitz sc
Old Feb 23, 2007 | 05:44 PM
  #60
hip_2b_sqr's Avatar
Every once in a while my XB runs a little stange also and have been instructed to pull the fuse for the ECU and let it reset itself. It has worked good so far. Also, are you running high-test fuel only? You HAVE to run high test with a SC'er.
