Garrett Turbo HELP
Old Aug 4, 2008 | 02:22 AM
FOSTER's Avatar
Default Garrett Turbo HELP
Thanks in advance....
Installing a turbo system on my toaster. got a used kit for a good deal.
Still new to the turbo scene, problem im having is where to hook the Wastegate to, I think it needs push rather than suck to actuate? the turbo appears to have no ports to make the wastegate open....
wut do i do?
THANKS
FOSTER
Old Aug 7, 2008 | 06:40 PM
arizonaturbo's Avatar
You can remove the compressor housing, drill and tap a new port on one of the flat spots on the housing for the actuator or tap after the throttle body.
Old Aug 7, 2008 | 07:11 PM
FOSTER's Avatar
Hey thanks for the info Pal.
I think i will tap into the intake manifold after the T/B like u have said, i need a port for a boost gauge too, and blow off valve.... a local fellow says hook the wastegate to the BOV so when the gate opens it also dumps the BOV, but that doesnt sound right to me.
THANKS
Old Aug 7, 2008 | 07:29 PM
xceptionalauto's Avatar
Default wastegate hookup
Drill a hole in the flat spot right by the discharge on turbo. Your boost source for wastegate should be at turbo not in intake. You should have no more than two things running off of a single line if you run it off the intake.
Old Aug 8, 2008 | 06:18 PM
FOSTER's Avatar
Seeing as how the turbo is already installed, rather than remove it and drill/tap for wastegate hookup, would removing the intake tube that bolts to the turbo to weld in a bung work ok? it would be only acouple inches up from the 2 blank boss' that can be seen on the turbo in the picture I posted. it would take only a couple minutes to unbolt rather than a couple hours to get the turbo out...
should the intake manifold be tapped for BOV and Boost/Vaccum Gauge right close to the T/B or is anywhere in the manifold sufficient??
Thanks Again for the Tech Help!!!
FOSTER
Old Aug 8, 2008 | 06:31 PM
FOSTER's Avatar
Old Aug 8, 2008 | 06:37 PM
Cinderblock's Avatar
is this just some pieced together custom kit? you should do it right and take the time to drill and tap the fitting to the turbo itself.
Old Aug 8, 2008 | 07:05 PM
FOSTER's Avatar
I got the parts from a friend who took them off his xb, he wanted a stock setup for day to day driveability and economy. Plus his family uses the car so turbo was not a best choice.
I know that drill/tap direct to turbo is the best way, but i want to know if there is any other options 1st. But thanks for the opinion/information CinderB.
FOSTER
Old Aug 8, 2008 | 10:51 PM
i guess you could just tap the charge pipe itself near where it bolts to the turbo, but youll have to unhook it if you undo the pipping, and im not sure on this, but the Wg response might be a lil slower, but i doubt it if you keep it close. im no turbo guru but ill try my best lol
Old Aug 9, 2008 | 12:25 AM
FOSTER's Avatar
I've been into performance stuff for a while now, usually offroad trucks and v8's.....its funny how u feel like u know about sumthing untill u actually go and do it, hands on in your face is the way to learn and that indeed i am. i can have the charge pipe off, drilled, bung welded in and installed/hooked back up in like 20 minutes, which beets 4+ hours of removing and modding/installing the turbo!
Thanks again for the help CinderB
FOSTER
Old Aug 9, 2008 | 01:20 AM
ya, im versed ina few things, i gota ranchero with a v8, i race in a 8100 class truck, have my 89 supra and the box, and its all so diff, but its exactly why i know as much as i do lol. i love this kinda stuff really. gots say though, honestly i much prefer my little 4 banger tho that pain in the ___ carb v8 haha, not to mention the huge mileage diff.
Old Aug 11, 2008 | 01:51 PM
Default wastegate source
You will be fine if you put the line on the charge pipe. You just want to get it close to the turbo as possible.
Old Aug 11, 2008 | 04:08 PM
thats kinda what i figured, just keep it close.
SloTC1
Aug 16, 2018 02:45 PM
greytc
Oct 26, 2015 07:53 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
