Has anyone swapped a 1ZZ Throttle Body?
Old 10-14-2007, 10:24 PM
EasysBox's Avatar
Default Has anyone swapped a 1ZZ Throttle Body?
I was wondering if anyone had swapped a 1ZZ throttle body into their box yet...
EasysBox is offline
Old 10-15-2007, 02:45 AM
swartzautoman's Avatar
never considered that befor.
is it bigger?
swartzautoman is offline
Old 10-15-2007, 03:33 AM
EasysBox's Avatar
considerably... im going to fab my own attachment to the SC, but i was just curious about getting the sensors to work right...
EasysBox is offline
Old 10-15-2007, 02:31 PM
IowaSciontist's Avatar
The only sensor on the TB should be the TPS. And it is adjustable. Try to find out what voltage it shoud be putting out at WOT, then use a ohmeter to test it while setting it. Let us know how it works out for you. You may want to try an portmatch the part for the SC too.
IowaSciontist is offline
Old 10-15-2007, 03:16 PM
EasysBox's Avatar
there is the TPS and there should be a Idle control unit as well... i was just hoping that someone had already tried this before i start hacking up my harness...
EasysBox is offline
Old 10-15-2007, 09:21 PM
Is the idle control on the throttle body, or the manifold. Have never really looked on the xB. Mine on my RB25DET is on the manifold.
The idle control is not necessary anyway. It is only controled my the engine temp thru the ECU for start up on cold days. You can eliminate it and use the adjusting screw on the TB to adjust idle. That's what I did on my RB. Most guys do. But it makes it like a carburated car on cold days.
Old 10-15-2007, 09:59 PM
EasysBox's Avatar
using the screw to adjust the idle would be easy enough... problem is, without the control connected wouldn't it throw a CEL?... is your RB in a 240? or is it still in the original car? ;)
EasysBox is offline
Old 10-15-2007, 10:03 PM
S13 chassis.
And yes, it may throw the CEL. Have to try and figure a way around that. Let me do some research. Mine on the RB wouldn't because I was running a Apexi Power FC stand alone.
Old 10-16-2007, 12:17 AM
EasysBox's Avatar
stand alone would solve the problem wouldn't it ;) post up some pics of your S13, would love to see it...
EasysBox is offline
Old 10-22-2007, 03:13 PM
HoffmanScion's Avatar
You may want to check into OBX. I know they have a replacement large bore throttle body for the 1NZ-FE.
HoffmanScion is offline
Old 10-22-2007, 07:18 PM
EasysBox's Avatar
do they, now that is interesting, thanks
EasysBox is offline
Old 10-23-2007, 06:29 PM
Yea, check LastLook Customs & Motorsports. I know Stu sells OBX
Old 10-26-2007, 11:55 AM
Steve60's Avatar
This is interesting.
If your aircontrol unit starts to screw up you will get a 0172 at the very bottom.
With the SC the OE TB is on the small side & the air control is a problem, it's happened with this car.
Hoffman thanks for the info... I like it. Bigger TB, just need to figure the fuel control unit into the mod.
Steve
Steve60 is offline
Old 12-03-2007, 05:47 AM
BurxBox's Avatar
what size is our throttle bodies anyway. OBX has a 50mm TB
BurxBox is offline
Old 12-10-2007, 12:40 AM
Black_Sheep_xB's Avatar
I think ours is 45mm, I heard the OBX was a 5mm increase
over stock.. 9% bigger, which is probably about right for our
wee motors.
Black_Sheep_xB is offline
Old 12-10-2007, 05:03 PM
so could i swap over to the OBX with with no other mods.
Old 12-10-2007, 05:24 PM
Steve60's Avatar
That would be a yes, according to what I'v been told. I have ordered 1. The bad is I won't see it till Feb.
The most important part of the increase in size is how the bell & the back side of the butterfly are treated. For now, no got so no comment....
Steve60 is offline
Old 12-10-2007, 08:05 PM
FoeShizoh's Avatar
very interesting. new to mods.
FoeShizoh is offline
Old 05-06-2009, 12:43 AM
crxgames's Avatar
Not to revive an old thread, but I did this last weekend. 1zz-fe 60mm throttle body swap from a 1998-2002 corolla. I wrote a DIY over on clubxb if someone wants to look it up. It is *definitely* worth taking the time to do.
crxgames is offline
Old 05-06-2009, 01:03 PM
i searched and searched clubxB and couldn't find your thread
i even searched google.
could you post a link the your thread
Quick Reply: Has anyone swapped a 1ZZ Throttle Body?
