supercharging safe?
Hello, I am on my way to modding my xb. I have the intake and I'm going to do a header and exhaust. My next step would be supercharging. Would like to know if supercharging with these modifications will be safe for our engines. I would like to keep the car for 100,000 miles or five years. I'm not a hard driver, but like to have fun every once in a while. I'm just nervous about pumping up output on these engines.
Thanks.
Thanks.
You take a risk whenever you put an aftermarket product on your engine. Can you supercharge your xB and never have any driveability issues? SURE! But I would get someone or shop you trust to install it if you have never done it before. There is always risk with forcing anything into your engine to make more power......but if done correctly you won't have any problem. I think the main issue with superchargers/turbos is expertise in installation and maintenance.
the kit that are available are all pretty safe, one shop snapped rods during a development of a turbo. alot of people have been running boost without problems. It sounds like you and your bro know what you are doing, you shouldnt have any trouble.
Basically the answer is 'nobody knows'. Some talk of doomsday from rods failing, yet there is no real substantial evidence to say they THEMSELVES fail and could be failing from horrible tunes. For all anyone knows you could pump 20psi in this motor and have no problems.
This is what happens with new groups of people trying things out on a new motor.
As a side story, when the Series 2 Supercharged 3.8L motor from pontiac went into service and people started modifying it in 98", they were doing intakes and such and that was about it. It was common belief that if you pushed the motor anywhere passed the 8psi it made stock that it would fail horribly. Someone made it to 10 but rumors were abound that they would REALLY start to fail very very soon.
Here it is 2006 and the Series 2 community has 4 cars in the 9's@over 140mph on 20-30PSI on STOCK pistons and rods.
It's all about trial and error and properly fueling the car, and working WITH the ECU to make sure it's happy.
So in short, who knows
No, I didn't even know we had them around here. Closest one I was able to find is in ct.
Besides, once I go F/I i won't be much of a competitor in the class i'd be in.
Yes its safe, f/i or any n/a motor is safe so long as you prep build for this.
Please search next time, there are tons of topics covering f/i and the 1nzfe. Don't mean to be rude, but by doing so we have one less new thread about something covered x10.
But just to help you out a little, here are some basic mods you could do to ensure your motor/tranny clutch to last.
Say you buy the blitz s/c, since thats most common here:
Automatic mods:
i/h/e to ensure the motor is breathing right, something you don't have to do but i would recommend it.
Synthetic tranny oil
Synthetic motor oil
Automatic Tranny fluid cooler (ATF cooler)
Piggy back. (camcon, e-manage, so on) to properly tune
Manual:
i/h/e
Manual trans synthetic fluid
Motor synthetic oil
ACT/SPEC/etc. "stage 2" or even "stage 3" clutch, (stock slips way too easily)
Piggy back. (camcon, e-manage and so on) to properly tune
Thats some basic things. I would also suggest, but not something you absolutely need would be gauges to watch engine temp, fuel mix and psi levels. Mostly for show, but this also can come in handy when it comes down to possibly problems running too lean or too rich. Also upgraded fuel rail/pumps, 8:5:1 pistons (zpi makes them), and the list can go on as far as what you can do. But above, imo, is stuff you really should do to ensure a long lasting f/i set up.
Automatic mods:
Synthetic motor oil
Manual:
i/h/e
Motor synthetic oil
Automatic mods:
Synthetic motor oil
Manual:
i/h/e
Motor synthetic oil
Automatic mods:
Synthetic motor oil
Manual:
i/h/e
Motor synthetic oil
Automatic mods:
Synthetic motor oil
Manual:
i/h/e
Motor synthetic oil
Automatic mods:
Synthetic motor oil
Manual:
i/h/e
Motor synthetic oil
The only thing you would need to pull the motor for is the pistons.
Automatic mods:
Synthetic motor oil
Manual:
i/h/e
Motor synthetic oil
Automatic mods:
Synthetic motor oil
Manual:
i/h/e
Motor synthetic oil
svt, there are people with s/c'd xb's pushing 60,000 miles. At least, i know of one. He has had zero problems and has driven it pretty hard going to tracks and the sorts for a good amount of time.
While long term effects, are unknown. If you built the car to properly support boost, the damage compared to a stock 1nz will be comparable. Yes, it puts extra stress on the trans and motor. However, using proper oil and proper tuning with specific mods backing up the support of the motor, you will have nothing to worry about.
If you are this deeply concerned, don't boost your motor. I mean seriously, no offense or anything but if you are this worried about what could happen even with a prep-build towards boost, why bother? Do what ever you feel is safe for you, but having this much doubt tells me boost isn't something you should do.
There are a few folks running 10-12 psi daily, they have reported no problems. all of the research done by trd, blitz, greddy and a few others supports that 6psi is completly safe for this engine.
TRD had a turbo package for this engine in japan, i believe we miss out due to emissions. I don't think they would have done that if it wasn't safe in the long term.
*p.s. a well maintained toyota engine is good ( by good I mean good not drivable but guzzling gas and oil)for at least 200,000 miles, so even if boosting it were to cut its life expectancy by 50% you would still be set
Thanks for all your help. I'm not so deeply concerned. I guess I just need to get some positive perspectives. I would love to and will be doing this mod. I hear many sides of doing this mod. It's just alot of money to spend to find out i shouldn't have done it.
I think you couls S/C this engine and be okay, but you'd have to go with a pretty gentle push in the psi dept.. It's been a pretty tempting thought for me as well, but I have the same concern. I'd like to keep my car for a while, and that keeps me from moving towards this. I tend to feel like pushing the engine like that would make a situation where if you made it to 100k milage, your car would have the wear of maybe 150k, and so on. I think it's kind of like thinking about buying a car from someone you know has driven it like an ___-- the wear on it passes what the mileage shows.
I still think an engine swap might be cool down the road. Either way (s/c, turbo, swap, or any combination of them), a few years down the road here in California, it still wont be smogable.
Still, it would be nice to get in and know that, even though the engine looks like it came off a lawnmower, now it'll drive like a car.
I would do it, but not if I wanted to know the car was in it for the long haul.
Originally Posted by Rocket
I just SuperCharged Mine at 3,000 miles, I let you know in a nother 97,000 if it was safe...(I hope so)
