xb turbo
Strictly Scionized
i have a xb im looking in to geting a turbo. but im concerned about blowing up the motor the company told me its a bolt on and i dont have to do any internal work but i dont know what do you think. shuold i go for it and leave every thing stock or should i upgrade some stuff first im on a low budget
This is what the search button is for. There are plenty of writeups on turbo kits in this forum. All with more than enough info.
Be safe and use an engine management system and keep the boost at a reasonable psi.
Electronic boost controller or spend them money on a standalone system like Autronic and you won't have much to worry about. Plus it is easy to tune yourself after a quick display from an experienced tuner.
Stock clutch will slip. That is the only part of the transmission that won't hold up. Get a new clutch and you should be fine. ZPI hasn't broken axles or any other part. All they did was wear out the stock clutch.
SloTC1
Aug 16, 2018 02:45 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
