*Help*Scion Xa Security System/with Keyless Entry
i just got my aftermarket head unit and OEM Xa Security System/with Keyless Entry installed yesterday.. everything was great but the remote only works with key in the ignition & head unit on... (only unlock panic works while the head unit and key is in ignition/ lock doesn't work since the key is in ignition) i tryed with key in the ignition with head unit off but remote didn't work... does anyone know how i can fix this or what went wrong?
thank you joshboogie i will try that when i go back to my friend's shop
anymore idea? i mean it seems like it works fine but only when car is on and head unit is on so its pretty much wiring rightt? just like joshboogie said. anymore ideas and info would be great, thanks a lot SL members
Sounds to me like the head unit was wired up incorrectly and is disrupting power to your security system. I've installed an xA security system before and its all plug and play so I don't see how that could have been installed wrong. So my guess is that its the head unit thats messing everything up(or the wiring of the head unit).
Sorry I cant be of more help, never heard of this kind of problem before. Try printing this PDF (http://installdr.com/Harnesses/Toyota-Wiring.pdf) and give it to your friend at the shop, he'll be able to look at that and tell if something is wired wrong with the head unit. On a side note, there is a chance that you might have gotten a faulty security system, but this is unlikely.
Did you chop off the factory harness for the headunit? or use one that will plug in?
I think it sounds like the constant for the alarm is connected an accessory (switched) lead. If it only works with the H/U on them it might even be connect to the remote. How that could have happened I have no idea but I'm not the one who installed it.
Here is a link to the instructions:
http://trdsparks.com/install/08586-52970inst.pdf
If it doesn't open copy the link, open Acrobat Reader go to file, click open and paste the link into the "File Name" section. The only reason I'm telling you this is because it didn't open for me.
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
user9430961
Sep 15, 2015 03:16 AM
