2004 xB Reverse Camera installation..
Old Apr 3, 2012 | 07:35 PM
danman2_2999's Avatar
Default 2004 xB Reverse Camera installation..
I am looking for a piece to cover the hole on the hatch where the wiper arm used to be.
I did a lot of searching for a DIY post for installing a back up camera on an XB1 but only found old threads with expired photo links, so I was hoping those who have done this mod can maybe help me out.
I purchased a JVC KW-AVX748 headunit from Amazon for about $320 shipped. It supports a back up camera, which wasn't a high priority for me, however when I saw how cheap some cameras were, I went ahead and bought one of amazon for about $15, which I am going to further weatherproof before installing to prevent moisture from entering the lens. (
Amazon Amazon
So I had read about people removing their wiper arm and using that hole for a good location.
Initially I had hoped to mount the camera under the third brake light inside the car, to prevent moisture and thieves, however I was not able to see out of my dark tint. I checked right above the license plate, below the hatch handle, and that seemed like a good location being under the hatch to protect it from rain drops, but was sorta low to get a good picture of behind the car.
So I went with the wiper arm hole, which I broke the retainer clips on the inside of the hatch to get that board off, exposing the wiper motor. Unfortunately I will need to purchase more of those or some clips to reattach that board (which i posted a different post). I also destroyed the rubber grommet piece that seals the wiper blade trying to modify it to allow my camera to stick through it.
Well I got the wiper arm off, but the camera didnt stick out enough to get the view that I wanted, so I am going use the spot under the hatch handle.
I was hoping anyone could point me in the direction of their clean installation, as well as access to the retainer clips, and also another piece that I can use to seal that hole from the wiper arm.
Thanks!
_____________________________
Old Apr 4, 2012 | 12:12 AM
BiteXb's Avatar
Is this what you want?
http://www.ebay.com/itm/04-09-SCION-...88b592&vxp=mtr
Old Apr 4, 2012 | 01:52 AM
Sciond's Avatar
mine fit well in the wiper hole....I was able to get a perfect straight shot.. what is stopping you? You could use a type of trim ring or washer or grommet and save the headaches
Old Apr 4, 2012 | 04:38 AM
Hey guys, thanks for the replies.
Thanks for that link to the eBay page, I honestly didn't even think to check there for that. Thanks for that info!
Basically, what is stopping me from using that camera hole is that I do not have a rubber seal to finish off the clean job.
I am not sure if I should take the camera to Home Depot and start looking for rubber grommets that may fit that hole or what. I am a little reluctant to start drilling away at that hole, however that is also another option.
First I must find the appropriate grommet, and the one that I cut up that was for the wiper ended up not working (stupid me for cutting up an expensive OEM part that I'd need to replace if I hadn't just saw that eBay listing).
I was hoping anyone with this install would be able to clarify what they used.
danman2_2999
Apr 7, 2012 06:42 AM
excaka
Aug 28, 2009 09:45 PM
DAILYXB-TYPE-R
Dec 27, 2008 12:28 AM
xBbeatBox
Oct 21, 2008 10:53 PM
SciFly
106
Dec 3, 2005 03:14 AM
