About the stock pioneer single disk radio
sure you can put amps on any radio including stock. all you need is a line converter, which takes the speaker leads and converts them to RCA outputs. Also some amps have speaker level inputs right in the amps. Then you'd run wire from the amp to the speakers. Or just tap into the stock wiring for the speakers from the amp.. so yes it's possible.. hope that helps you
thanks man. ill go with the tapping on the rear speakers.... got some rca's from radio shack and will try tom.. another question... is it possible to connect my undercar neon lighting to my dome ligh coz i kinda like it when i lock the doors and the dome lights just fades. and when i use the keyless entry i want the neon lights to go on too????
Not really a good idea to hook up your neons to the dome like that, neons wont fade, pretty much they are either on or off, just the way they work. It all has to do with them having to heat up and all that technical stuff i know about but not enough to explain
wiltonhall
01-28-2015 03:46 PM
