Advice...wiring underdash cold cathodes to a switch...
I'm going to tap into the cigarette lighter power to run them....I was just wondering if i should use a separate ground or can I just tap into the ground for the cigarette lighter? Any suggestions or advice is appreciated....
you can use the cig lighter for power and ground. there will be no problem with that. just remember that you have to turn the key on for the lights to work, so you will not be able to sit with the car off and have the lights on.
Originally Posted by ElChupacabra
Add-a-circuit. Grab one at Pep Boys, Autozone, NAPA, or whatever your local automotive store is. I think they're like $5 and worth every penny...
Originally Posted by Neothin
inccorect (sort of)
you have to find a fuse that stays live (+12v) at all times. Some fuse slots only go active when the car is on, or something else is turned on.
ive got a box, that i got at pep boys, runs 4 different applications. 2 have my Varads Leds, car doesnt have to be on has a nice 4 pad flat touch pad switch. cost like 20 bucks...worth it!!
airmankevin1
Nov 17, 2015 05:44 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
