Aftermarket shifters?
Old Sep 11, 2007 | 09:17 PM
greenninja5150's Avatar
Default Aftermarket shifters?
Doesn't anyone make a decent short throw aftermarket shifter for the XB? I took out the RS Type shifter that I had in the car today after having to drive home last night from the Niners game in 3rd gear! The "lock" washer came off the shifter and it came apart and wouldn't shift into anything other than 3rd. I guess it could have been worse it could have been reverse! I drove home one time in my 65 Mustang in reverse but that's another show. The RS Type shifter was supposed to have a shorter throw than stock but in reality it was only about a half inch shorter and felt mushier than the stock shifter was. I can't believe that B&M or Hurst or someone else doesn't have something. Is the shifter different for the XB, XA and TC? I've driven a stick for 26 years and I'm not used to such a sloppy feeling shifter. If you've ever driven a car with a nice Hurst you know what I mean.
Old Sep 11, 2007 | 09:34 PM
JSosa's Avatar
i feel you. Our shifters are clunky, squeaky, vague and just pretty much $hitty!! I HATE HATE HATE that part of my car, probably the worst part on it. I as well had the RS type shifter on my car and just like you, i was disappointed, it only a 20% shorter throw from neutral into 2nd, 4th and reverse, the other gears are just as long.
Mine didn't come apart i TORE it apart, piece of $hit!!! I was so annoyed and i just couldn't take it anymore i removed it from the car and threw it across the garage and till this day its still there, that was about a month ago.
If you want better shifting, more control and less vagueness, get a Perrin short throw. You will need your OEM shifter housing, because your going to remove the old shift rod and replace it with the Perrin. Now, dont expect any silky smooth shifting or a better shifter fell because its just NOT going to happen. I applied grease, oil, sweat, tears and blood and this things still shifts like a truck. Ive just learned to live with it. At least with the Perrin you get the option of having a 20%-200% reduction in throw. If you need any more information, let me know.
Old Sep 12, 2007 | 01:32 AM
ShadowOnTheBayou's Avatar
+1 on the Perrin. It's a great unit. I've had it for a month or two, and it is a huge improvement over stock.
Old Sep 12, 2007 | 08:55 AM
superboxcarxb's Avatar
i drove a BMW m5 today. The shifts were super short, less than an inch between the little gears....The clutch, OMG, as soon as you depress the clutch...AS SOON AS you do....You can gas it! wow. what a nice car...
Old Sep 20, 2007 | 04:15 PM
EasysBox's Avatar
B&M does make a shifter for the box, like the perrin you keep your oem housing and swap the rod.
Old Sep 20, 2007 | 04:39 PM
Yeah I saw that. Actually I meant a complete shifter. One that will actually improve shifting not just make the throw shorter. This is the worst shifter I've ever had to deal with.
Old Sep 20, 2007 | 06:02 PM
JSosa's Avatar
once again, i feel you, i TRULY feel you!
Old Sep 20, 2007 | 07:07 PM
what does the perrin come with? is it just the stick or the whole assembly?
Old Sep 20, 2007 | 07:32 PM
All you have to do to find out is read the posts in the thread. Just the stick.
Old Sep 21, 2007 | 11:56 PM
that sucks. i don't want to re use the old plastic base...
Old Sep 24, 2007 | 01:52 AM
Default exactly my point....
all that does, it seems to me, is make a "lousy" short throw shifter. Oh well. Maybe someday!
Old Oct 7, 2007 | 08:41 PM
silverstreaktc's Avatar
TWM....TWM...TWM...TWM...TWM...TWM...TWM...TWM...TWM...TWM...TWM...TWM...TWM...TWM...TWM...SHORT SHIFTER!!!
Old Oct 8, 2007 | 04:55 PM
Suburban_Assassin's Avatar
I had the B&M and I liked it. The only thing I didnt like was the height of it. So I took my stock shifter, cut it and rewelded the top part and also extended the bottom making a true short throw shifter rather than just a shorter grip. The B&M is a true short throw shifter because the kit comes with spacers that raise the white housing up from the car and the bottom of the shifter is .5"+ longer than the stock shifter (which I matched with my remade shifter). Also, what does it matter if you reuse the stock housing? BUT AS FAR AS MUSHINESS. . . I havent done it yet, but they make brass shift bushings that should help with the feel. CorSport makes them and if you pair them with the base bushings, it should be a little bit more stiff.
http://www.corsportusa.com/store/cat...roducts_id=491
http://www.corsportusa.com/store/cat...roducts_id=635
Hope that helps.
Old Oct 10, 2007 | 06:53 AM
BlangKang's Avatar
Hope that helps.
could you give more details on extending your shifter? I am planning on cutting the stock shifter down but also want a shorter throw. Thanks much
BlingSlade
Nov 20, 2015 06:56 PM
jdmautoimports
Regional - Canada
Sep 24, 2015 04:00 AM
kslim619
Sep 18, 2015 06:54 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
