AIR FUEL Gauge install HELP!
StyleWagons
Ok so I do the search thingy... what an a$$ whip....
I found a guy with a TC in the xB lounge who has the same Q as me, I digress....
I have the AC autotechnic A/F Gauge, need to know what wire to hook it up to PLEASE!
I don't care if you think its a waste or stupid or whatever (every other person I found doing a search who asked this question got flamed, along with not gettig their question answered......)
I want it for looks, and i'm ok with that, I have 7 TVs in my frickin car, by god I have a right to do retarded stuff to it!
Ok i'm calm...
PLEASE HELP!
Thanks ya'll
-TR
Ok i'm calm...
PLEASE HELP!
Thanks ya'll
-TR
12V wire to 12V switched source, ground wire to ground source, signal wire to O2 source. Done.
Don't know what the O2 source is? Find a print out of the ECU wiring and tap the O2 wire. Or tap the signal wire directly off the O2 sensor.
Good luck with the eye-candy gauge.
Here is a picture even...
StyleWagons
Ok, this is exactly the problem, I don't have a schematic diagram of the ECU...
And I don't know which wire off the sensor is the right one. But the instructions on the
gauge said don't mess up or your gonna fry the sensor.
Is that a xB ECU in the pic, and if so is the wire tapped the wire for the gauge that i'm
seeking?????????
If so your awsome!
Either way thanks Roman Nova.
If not, sombody please help!
AHHHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!
I'm ok,
-TR
There is another way but it is more expensive and you need access to a exhaust shop. I have a autometer air/fuel meter and when I was looking for the right wires I showed the wiring diagram to my pops. He's been a mechanic with a specialty in electrical systems for about 30+ years. The first thing he tells me is "hell no you're not tapping off a wire that goes into the ECU." The second thing he says to me is "why do you keep doing things to your car."
My reply, "1967 Camaro 289 small block motor swap, with manual to a two speed auto conversion." I could see a tear start to form in his eye and he turns around and says, "just order the sensor kit." and then he walks away.
but I digress.
So I ordered a kit and I will putting a separate o2 sensor in. It will require that I drill a hole into the exhaust before the catalytic converter, and welding a bung in. If I ever decided to take it all out, the kit I ordered actually came with a plug for the bung (hey no laughing).
If you decide to tap the ECU wires then try pm'ing INSIDEOUT
He had a thread started with your very same question. I pm'd him a little before I decided to get the kit. I believe he knows. Good Luck.
If you figure this out post it please. Cause I searched this and several other sites and all the posts regarding the A/F meters always just kinda stopped.
but I digress.
seeking?????????
If so your awsome!
I'm ok,
-TR
As far as tapping off the ECU, there is nothing wrong with that. Use a vampire style tap and you'll be golden. If you have no idea what I am talking about, you might consider having someone else do it. You can always consider a wideband which requires welding a bung onto your exhaust and running an additional o2 gauge, but again... you can't change anything unless you have an AFC or Camcon... but even then unless you can log the changes... why bother?
GL
All you Need to do is crawl you fat butt under the car( That was my problem) Then grab your volt meter, Ground it out set it to volt's look for the the O2 wires coming out of the o2 sensor there should be 4 wires, I think the colors are two black wires one white and one gray, Turn the key on................. It must be on or you are ____sing in the wind.......... Take the pointy end of the volt meter tester stick it to the gray wire it should read .01 volt if ir reads 0 you are touching the ground if it reads 12 you are on the power wire for the o2... Do not hook i up till you make sure it is the .01-.05 volt wire or your air fuel gauge will fry!!!!!!!!!!!!!!!!!!! It can not read 12 volts it will implode..
JM Auto Racing
12-19-2014 06:36 PM
mattjk
121
12-22-2004 10:49 AM
TheRedBox
31
12-02-2003 04:53 PM
9186980189, ac, af, air, autotechnic, diagram, diy, fuel, gauge, instal, install, installation, scion, voltage, xb
