amp install/ rear Xa wire harness
Old Jul 14, 2004 | 11:17 AM
ag2si's Avatar
Default amp install/ rear Xa wire harness
I tried the search but still did not get a deffinate answer out of it. Does the Xa/Xb come prewired for the bazooka tube, i.e. if you don't have the bazooka installed is the wireharness already there anyway just tucked in either one of the side panels or under the rear seat? If it is there, has anyone used it to serve as a signal source for an aftermarket amp? We will be using a MTX Thunder series amp which comes with speaker level inputs so there is some install flexability.
Old Jul 15, 2004 | 10:56 PM
hizkidd's Avatar
The wiring harness isn't there at all. I think it get's installed if you order the bazooka from the dealer. I installed an aftermarket amp and sub and had to splice into the rear speaker wires and use a line converter. It would have been much easier if the harness was there, but, alas, 'tis not!
wiltonhall
Jun 23, 2025 10:09 PM
O5_TRD_tC
Feb 18, 2015 09:01 PM
clickclickw00t
Feb 18, 2015 08:57 PM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
Scion_707
Dec 31, 2014 03:28 AM
