Amp Question
I have two amps that are the same, they do not have RCA outputs. The question is I want to daisy chain them so can I use a RCA Y-cord to do this, meaning 1 male 2 female outlets?
John
John
are you using both amps for subs??? or both for mid/high.... the reason I ask is, if you have an aftermarket HU, you'll probably be able to "tweak" it better from the HU if you have the front RCA's ran to the mid/high amp and the sub RCA's ran to the sub amp...... if they're both being used for the same type of music, yes, you can use the y-cables....
bootlgr
Jan 26, 2016 01:22 AM
