Anyone bought the OBX fatboy sport shift knob?
Anyone bought the OBX fatboy sport shift ****?
I've installed it and now I've got the following problem...
the instructions say...
if needed raise the "shift boot collar" until it is flush with the ****
the "shift boot collar" is the skirt that's underneath the ****. the problem is that there is now a rattle, because the factory **** went all the way down to the collar. :-/
anyone have a similar problem? thoughts?
yes, now follow this closely it is hard to describe...
ther is a RING around the shifter arm that holds the collar up...you have to feel for it through the leather! it is a plastic ring that holds the collar up
once you raiSe the shift boot collar up...SLIDE THIS RING UP THE SHAFT OF THE SHIFTER and it will click into the bottom of the collar and hold it up
Pop the shift boot ring from the console and tip upside down.
I did the pop up thing at first but after much use it pops back down and makes the rattle again. So i flip it over again and then took Rubber tape and shoved the plastic ring up tight to the top and wrapped the rubber tape, it also helps absorb noise so now it's tight and right........It's easy, YOU CAN DOooooo IT !!!
I did mine and it's fine now !!!
i see what your saying but even with it tight to the **** they are still slightly visible maybe i am being to picky thow hey mile_hi you by chance wernt refering to the snl parody of chronicals of narnia mr. pibb + red lace = crazy delicous
Originally Posted by punxnotdead
Maybe I'm reading this wrong...but,if not..how do you take the shift boot out without removing the whole console and then how do you put it back in?
I followed a tutorial posted by Mikochu when I installed my OBX shift ****. Here is the link. https://www.scionlife.com/forums/viewtopic.php?t=38358 Hope it helps.
NonStopTuning
06-29-2015 07:42 PM
