Anyone have one of these in their Scion yet?
Originally Posted by 93Rubz
George, Can't pull the link. Look for power spots for two radios. a kenwood tmv-7a and a kenwood commercial radio.
73
KB9rto
73
KB9rto
For power, I ran 10ga wire direct from the battery through the left hand firewall boot. There are fuses on both the feed and ground leads. Once into the cabin you can do just about anything you want. Mine goes across the shifter hump and out under the right seat where the Icom xcvr module is located.
The antenna was very easy. I used an Austin tri-band antenna on a Larson magnetic base. The magnet mount is located at the extreme rear left corner of the roof which allows the coax to enter the car through the rear hatch seal. I made a drip loop at the bottom to keep water out and secured the coax to the screw that is located at the lower left corner of the hatch. The coax goes across the spare tire area, under the rear seat, and up via the threshold panel in the rear and front door opening.
I'll post some pix later on.
ScionLife Editor
Dec 6, 2014 11:58 PM
ScionLife Editor
Nov 28, 2014 11:10 PM
ScionLife Editor
Nov 25, 2014 03:00 PM
ScionLife Editor
Nov 20, 2014 05:20 PM
foxSCION
13
Dec 3, 2003 05:40 AM
