Anyone have pics of the XB door without the panel on it?
Old Apr 3, 2005 | 12:50 AM
drew05xb's Avatar
Default Anyone have pics of the XB door without the panel on it?
I am trying to get an idea of how much sound deadening I need to buy and I was hoping to take a look at the door, but I dont have any tools.
Old Apr 3, 2005 | 12:59 AM
T_Dot's Avatar
1 package of sets that do the whole car, will actually to the whole xB, include all doors and most of the roof.
Old Apr 3, 2005 | 01:56 AM
drew05xb's Avatar
What do you mean by package of sets?
Old Apr 3, 2005 | 03:25 AM
T_Dot's Avatar
they dynamat package ths is suppose to do the whole car.
Old Apr 3, 2005 | 03:38 AM
dgHotLava's Avatar
this what you need...
Old Apr 3, 2005 | 03:50 AM
xbox1's Avatar
they make door kits but they dont have a kit that does the whole xb but depending on what dynamate you us is how far youll go i dyno my whole xb except the celling which im going to do later it cost me about 600.00 and i do car audio for a living so thats not retail but if need anything or any questions leave me a massage xbox1
Old Apr 3, 2005 | 04:45 AM
Piston's Avatar
When I did my dynamat, I did the outside skin to make the doors and the part of the door that you see above. for all four doors, it took 12 Sheet of Dynamat Extreme. So far I have done 6 case of the extreme, each case has 9 sheets.
Jason
Old Apr 3, 2005 | 06:17 AM
drew05xb's Avatar
I'm trying to figure out if I can do both doors with 40 sq. ft. I am planning on getting edead v.1.se and doing a layer on the outer skin a layer on the panel itself. Then doubling up on all the other spots that aren't completely dead.
Old Apr 3, 2005 | 02:38 PM
AKgoalie7's Avatar
do you put the "mat" on top of the plastic?
Old Apr 3, 2005 | 04:45 PM
neckbonenick's Avatar
definately don't put the mat on top of the plastic. Under.
Old Apr 3, 2005 | 05:12 PM
drew05xb's Avatar
thanks man, that's exactly what I was lookin for
Old Apr 4, 2005 | 04:51 PM
ROBUPNYA's Avatar
so....do you rip the plastic off the door before you put the dynamat.....or, do you just put the dynamat right over the plastic???
Old Apr 4, 2005 | 04:57 PM
ROBUPNYA's Avatar
hey neckbonenick......what size drillbit did you use to get the speakers off....what was the process that you took to get it off????
Old Apr 4, 2005 | 05:30 PM
House_Of_Steel's Avatar
Default Anyone have the back drivers side door ?
Any pics of the back door off by chance ?
Thanks
Driver side back ...
Have to remove that small pane of glass and replace molding .....
Old Apr 4, 2005 | 05:39 PM
You want to mat underneat the plastic and the outter skin behind the window.
Old Apr 4, 2005 | 05:52 PM
Fujiz_xb's Avatar
sIcKsCiOnS
i dont remember the size..but just pick one and drill away...once you drill thru..your all done.
Old Apr 4, 2005 | 09:24 PM
xbox1's Avatar
i will try to puts some pics on before and after
Old Apr 4, 2005 | 10:51 PM
dgHotLava's Avatar
no, don't rip the plastic! thats the moisture barier.
use a utility knife to cut the black glue...then you can reuse the plastic.
as for the rivits...
use any size drill bit you have 1/4 inch or so should work fine.
Old Apr 14, 2005 | 10:24 PM
owenbaier's Avatar
Default Door panel removal
Do you just pop the door panels off? Then unplug the window controls?
I popped off my doors on my old Ford Taurus and those plastic clips soon degenerated to where I had to replace them and Ford price gouged the crap out of those things.
Thoughts?
Old Apr 14, 2005 | 10:35 PM
Pimpe_Ok's Avatar
Utah Scions
u should be ok our plastick clips are stronger cuz they new any old plastic tends to become brital. so u fine.
