anyone have plans or measurements for an under the seat box?
Originally Posted by Sciond
yes they get a bit warm..but no issues... I just bought some fans to keep air moving HOWEVER I ran multiple amps there without fans all summer
What kind of fans did you get, pc fans? Also, I was thinking about putting a bunch of smaller holes(not big enought to weaken structure) in the sizes of the foam to help bring in extra cooler air from the spare tire area, would this work?
no fans or anything here. Will update if I have any heat issues.
I imagine if it gets really hot, I could just leave the lid off unless i need to put something else in the car... That should be more than enough air flow.
I still have to wrap the boxes. I wasn't planning on using these as the finished boxes, but they sound good enough that I just might.
Hmmm...
Hmmm...
Here is what I did for my under seat sub 12" pioneer premier shallow mount.
http://www.clubxb.com/forums/f23/122...ighlight=audio
hope that helps.
hope that helps.
Maybe so If you only using 10's. I would check the proper cu ft needed for those particular subs and build your two boxes accordingly. You'll have to mount the amp in the back more than likely if your putting a sub under each seat.
Yeah was definitely planning on putting the amp in the back.
The ideal for the SQ10 is .5cF.
That would mean that jared_IRL's box would be perfect for these.
I just don't know if I wanna bend anything.
I know I have to take out the cover and the stuff from under the driver seat, is that what everyone is referring to as bending?
And if I do bend it, does it affect anything?
Take it all out and I put it in the cubby in the back, which you might have a problem w. that since you need a place to mount the amp at.
After the jack and jack cover have been taken out just bend the jack bracket under the seat either down or back out of the way.
Originally Posted by Iron_Lion_Scion
But then your window would be all jacked up. Badoom tissss....Yep I'll be here all week. LOL
Thanks for the picture.
Is that the red things?
And do I have to do anything on the passenger side?
